AN to NPT adapter. Is this right? #1785520
03/22/15 10:50 AM
03/22/15 10:50 AM
central Florida
titan Offline OP
titan  Offline OP
central Florida
Hey Guy's. just purchased a Carter Mechanical Fuel Pump For 340 It has 1/4 NPT female inlet/outlets. also purchased aeromotive 1/4 NPT to 8AN adapter fittings. I get MAYBE 2 threads screwed in before hand tight, & cant imagine getting much more with tightening allthough I have not tried yet for fear of breaking pump housing or fitting.instructions also state, NOT to use Teflon tape, so to me that would mean fittings would need to be seated pretty good for chance of no leak. what are your thoughts? Thank you
Re: AN to NPT adapter. Is this right? [Re: titan] #1785521
03/22/15 10:57 AM
03/22/15 10:57 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
you don't use tape but you need to use some Teflon paste.
Joe
Without Data, you’re just another guy with an opinion.
Re: AN to NPT adapter. Is this right? [Re: titan] #1785522
03/22/15 11:04 AM
03/22/15 11:04 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Take the pump apart and tap it deeper so you can get more threads
2011 Drag Pak Challenger
Re: AN to NPT adapter. Is this right? [Re: rickseeman] #1785523
03/22/15 11:15 AM
03/22/15 11:15 AM
central Florida
titan Offline OP
titan  Offline OP
central Florida
yeah, that's what I'm leaning towards, think I would feel the most comfortable.
Re: AN to NPT adapter. Is this right? [Re: titan] #1785524
03/22/15 11:43 AM
03/22/15 11:43 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
are you sure the carter pump doesn't have an inverted flare and not an npt?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: AN to NPT adapter. Is this right? [Re: Jerry] #1785525
03/22/15 12:22 PM
03/22/15 12:22 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
i just looked at the M60514 pump and it looks like it has a 3/8 inverted flare.
Re: AN to NPT adapter. Is this right? [Re: sr4440] #1785526
03/22/15 12:36 PM
03/22/15 12:36 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
this is the pump. http://www.summitracing.com/parts/crt-m6270/overview/
Re: AN to NPT adapter. Is this right? [Re: titan] #1785527
03/22/15 12:50 PM
03/22/15 12:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can be looking at 2 things that are out of spec..
the pump might be on the small side and the fitting
on the large size.. I see it a lot... easiest thing
is the run a tap in deeper into the pump(take it apart)
EDIT
the reason is the coating they put on the pump and
the fittings... its done after the threads are cut
Re: AN to NPT adapter. Is this right? [Re: MR_P_BODY] #1785528
03/22/15 01:16 PM
03/22/15 01:16 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I just bought the same pump and I just used Teflon tape and tightened the fitting with a 1/4" drive ratchet till it stopped and then added my inverted flare fitting. No leak at all. I wouldn't do anything till you see you have a problem.
Re: AN to NPT adapter. Is this right? [Re: MR_P_BODY] #1785529
03/22/15 01:17 PM
03/22/15 01:17 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
this is what it looks like with fitting as tight as i feel comfortable with.
Re: AN to NPT adapter. Is this right? [Re: titan] #1785530
03/22/15 01:28 PM
03/22/15 01:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself I dont like the fitting sticking out that far..
too easy to break them off... if you have your next
fitting on it and bang into it, its likely to break
off right at the pump
Re: AN to NPT adapter. Is this right? [Re: titan] #1785531
03/22/15 02:25 PM
03/22/15 02:25 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I would take the bottom off and run a 1/4NPT tap thru it too open it up a little, then seal it with some teflon paste.
Joe
Re: AN to NPT adapter. Is this right? [Re: titan] #1785532
03/22/15 03:27 PM
03/22/15 03:27 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Personally, after seeing that I too would run a tap, make sure it's a NPT Tap and go in so more threads are sent into the pump. Just don't go crazy with the tap.And remember to put a little grease on the tap so the shavings don't go into the pump but stick to the tap.
Re: AN to NPT adapter. Is this right? [Re: Sammy] #1785533
03/22/15 03:37 PM
03/22/15 03:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sometimes the details Summit gives on their website are not correct, My Aeromotive fuel pump had different fittings than what was listed on Summit's site, which threw me a curve ball after buying the wrong fittings.
Re: AN to NPT adapter. Is this right? [Re: Sammy] #1785534
03/22/15 08:24 PM
03/22/15 08:24 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'd prefer taking the cover off over grease , but when tapping with a pipe tap , go maybe a turn at a time.
They open up quickly , so it isn't going to take a whole lot to sink the fitting in where you want it.
Re: AN to NPT adapter. Is this right? [Re: ProSport] #1785535
03/22/15 08:24 PM
03/22/15 08:24 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
tapped out the threads & ran the threads of the fittings over my wire wheel bench grinder. all is well. Thanks fella's.
Re: AN to NPT adapter. Is this right? [Re: titan] #1785536
03/22/15 08:33 PM
03/22/15 08:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: AN to NPT adapter. Is this right? [Re: MR_P_BODY] #1785537
03/22/15 10:49 PM
03/22/15 10:49 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Wondering why you're running 8AN(1/2") into a 1/4" fitting??? , sounds like choke city to me.
