Use the studs or put in bolts on header install?
#178517
12/29/08 10:28 PM
12/29/08 10:28 PM
Ready to install my headers on freshly rebuilt 383 and wondering if I should remove the manifold studs and use bolts or leave the studs in? I am not even sure the headers will fit with the studs? The studs go into the water jacket so if they are removed what if anything needs to done to reseal them? I am using Heddman's cheapest set ordered from Summit (I puked on TTI's price), into a 71 Charger. Also I have the car completely dissembled and so there is nothing really in the way of putting them in, and for the install I will even be removing the torsion bars.
Thanks MoParts, thanks for reading and any help is appreciated!!!!
Re: Use the studs or put in bolts on header install?
#178518
12/29/08 10:59 PM
12/29/08 10:59 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I replaced all the bolts with studs again on my 440.Even with the aluminum heads and dry holes I prefer the studs.I swapped them in my old iron heads also.I only have bolts where studs wont fit.Thats I think 3 of them.Rocky
Chrysler Firepower
[Re: therocks]
#178519
12/31/08 03:30 PM
12/31/08 03:30 PM
thanks Rocky, you use anything on the bolts to seal them?
[Re: 1_WILD_RT]
#178522
01/01/09 04:08 AM
01/01/09 04:08 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
1 7/8 headers usually work with studs & I would use the studs if possible...With 2"& larger headers small headed bolts seem to work better but I wouls still try to use studs in the end locations...
Not much to add. On my 383 with 1-7/8" headers the studs worked great. With 2" headers some tubes would not clear the studs so I had to use bolts. On small blocks I alaways use the studs on the ends to prevent coolant leaks.
[Re: 451Mopar]
#178523
01/01/09 08:55 AM
01/01/09 08:55 AM
therocks
Niles , Ohio
Believe it or not I use silver anti sieze on the studs and bolts.Have done probally 6 cars and none leaked.Plus when you remove them they come right out.Rocky
Chrysler Firepower
[Re: therocks]
#178524
01/01/09 10:01 AM
01/01/09 10:01 AM
Posts: 3,379 KY USA
mopargem
KY USA
I always use Permatex Indian Head Shellac and by all means use the studs in the wet holes. You will be glad you did the first time you have to remove a header for a gasket leak or some other reason. The headers will fit over even if you have to remove an engine mount pin and slightly raise the motor on one side for install, that is no big deal, but I bet they will fit anyway.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
#178526
01/01/09 03:28 PM
01/01/09 03:28 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Studs with sealant if you have the clearance.
This is especially helpful if your headers capture your starter, or if you have a gasket leak.
