Blowproof Cluthc Housing Recommendation #1784303
03/20/15 01:34 PM
03/20/15 01:34 PM
East Aurora (Buffalo) NY
RoadRunner Offline OP
I am thinking about adding a blow proof housing as I swap in a 426 hemi into my Road Runner. Any recommendations? I am running a McLeod dual disc clutch set up with 130 tooth flywheel with Hemi fourspeed. I also plan on using TTI headers. I know Lakewood makes one. Is there a particular model or part number I need? I have read on posts here before about having to grind on flange to clear clutch linkage. Any other pitfalls I may run into? Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Blowproof Cluthc Housing Recommendation [Re: RoadRunner] #1784304
03/20/15 01:41 PM
03/20/15 01:41 PM
Up a holler, down a crick
booger Offline
booger  Offline
I had to cut about 3/4" off the Z-bar width to get a Lakewood installed in a 70 gTx. Other than that and grinding the tunnel lip it was pretty straight-forward.
The things weigh a ton and if you dial it in you'll probably be installing it more than once. So, do some push ups to get ready (or do what I did and use a transmission jack to do the lifting).
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: Blowproof Cluthc Housing Recommendation [Re: RoadRunner] #1784305
03/20/15 01:41 PM
03/20/15 01:41 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Quicktime makes a nice piece. My son is using one right now. In the past he actually had a Mcleod twin in the car. He did have to do some dialing in, but that's recommended with any after market bellhousing.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Blowproof Cluthc Housing Recommendation [Re: RoadRunner] #1784306
03/20/15 01:42 PM
03/20/15 01:42 PM
MI
68shifter Offline
68shifter  Offline
MI
What's your primary use? Street or strip?
Lakewood and QuickTime. The QT housing is a little smaller and lighter so easier to work with.
TTI also sells a z bar for use with their hemi headers and/or has some specs on what you might have to modify on your existing z bar.
http://www.manciniracing.com/bellhousings.html
The needed modification
http://www.ttiexhaust.com/Footnotes/28.htm
http://www.ttiexhaust.com/Category-ClassicHeaders/Hemi/TTiHEMI-218.htm
Re: Blowproof Cluthc Housing Recommendation [Re: 68LAR] #1784307
03/21/15 12:20 AM
03/21/15 12:20 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you are running a 130 tooth wheel the Quicktime is the one to use. From everyone I talked to be prepared to do some custom fabrication on your clutch linkage
Gus
64 Plymouth Savoy
Dana 60
Re: Blowproof Cluthc Housing Recommendation [Re: fourgearsavoy] #1784308
03/21/15 05:03 PM
03/21/15 05:03 PM
kansas
farmboy Offline
farmboy  Offline
kansas
I just sent back a Quicktime, that was was out of alignment. Total indicator run out was over .050. Quicktime tech didn't seem to care. They suggested offset dowels, even though, I am not aware of any that correct over .037. I hope they don't try and resale that turkey. Just installed a new Bohr aluminum, that checked perfect.
Re: Blowproof Cluthc Housing Recommendation [Re: farmboy] #1784309
03/21/15 07:13 PM
03/21/15 07:13 PM
Texas
mprhound Offline
mprhound  Offline
Texas
If you plan on running stock bell crank and stock linkage I wouldn't use the QuickTime
Way to many issues,I dealt with them during Dragweek last year
After finally getting the rinky dink bracket guested so it wouldn't bend the whole starter area of the bellhousing began flexing
I came home and found a lake wood to put in my car
Re: Blowproof Clutch Housing Recommendation [Re: RoadRunner] #1784310
03/26/15 02:53 PM
03/26/15 02:53 PM
Looks like the Lakewood unit, PN 15330 is just about impossible to get. The 15335 is available, but the center bore for transmission is 5.125" diameter versus my 4.80" diameter bearing retainer. I am not sure if anyone makes an adapter ring. The Quick Time unit looks like it has an adapter ring. I had planned on using stock z-bar and linkage. Maybe I will use stock factory bell housing until I can sort this out.
2023 Ford Mach 1
Re: Blowproof Clutch Housing Recommendation [Re: RoadRunner] #1784311
03/26/15 03:23 PM
03/26/15 03:23 PM
booger Offline
booger  Offline
My Lakewood came with the adapter ring. If you order one and don't get it, I'll send you the one I've got.
Re: Blowproof Clutch Housing Recommendation [Re: booger] #1784312
03/26/15 05:43 PM
03/26/15 05:43 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Back when I started racing I seen a chevy car blow a pressure plate , it came up through the floor boards then continued up and out in front of the wind shield. Basically totaling the car. Also while all that was happening the floor board metal was rapped around the drivers foot breaking it and secured him in the car. That made a pretty good impression on me at the time and ordered a lakewood as soon as I got home. Back then I still ran a stock flywheel and clutch assembly but felt secure knowing that everything would be retained in the Lakewood if something did let go. Dialing in the bell housing is just something you have to do on any aftermarket piece. If your just going to street drive just use what you have , if your going to do any high RPM shifting , do yourself and others a favor, buy a blow proof bell housing.
Re: Blowproof Cluthc Housing Recommendation [Re: 68LAR] #1784313
03/26/15 06:14 PM
03/26/15 06:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Quicktime makes a nice piece. My son is using one right now. In the past he actually had a Mcleod twin in the car. He did have to do some dialing in, but that's recommended with any, factory or after market bellhousing.
fixed
Re: Blowproof Cluthc Housing Recommendation [Re: JohnRR] #1784314
03/26/15 06:26 PM
03/26/15 06:26 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Blowproof Cluthc Housing Recommendation [Re: oldiron] #1784315
03/26/15 07:01 PM
03/26/15 07:01 PM
dogdays Offline
dogdays  Offline
Can't the 5.125" retainer be swapped on the transmission in place of the 4.80"? They're not that expensive.
R.
Re: Blowproof Clutch Housing Recommendation [Re: RoadRunner] #1784316
03/26/15 09:07 PM
03/26/15 09:07 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The 335 comes with that adaptor ring to run the 4.80. If you're running an early tranny with the 4.35 retainer you will need the adaptor ring for that as well. I countersunk the 4.35 ring into the 4.80 ring so it all goes together right for my '67 tranny.
Re: Blowproof Cluthc Housing Recommendation [Re: oldiron] #1784317
03/27/15 12:22 AM
03/27/15 12:22 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mopar to the bone!!!
Re: Blowproof Clutch Housing Recommendation [Re: GTX MATT] #1784318
03/27/15 10:14 AM
03/27/15 10:14 AM
Glad to hear adapter comes with it. Looks like I will order teh 15335 this weekend.
2023 Ford Mach 1
Re: Blowproof Clutch Housing Recommendation [Re: RoadRunner] #1784319
03/27/15 05:05 PM
03/27/15 05:05 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
PM sent
Joey
Re: Blowproof Clutch Housing Recommendation [Re: jake4cars] #1784320
03/27/15 05:40 PM
03/27/15 05:40 PM
rowin4 Offline
rowin4  Offline
What transmission takes a bearing retainer that is 5.125? I thought the 4.80 was the largest diameter
Re: Blowproof Clutch Housing Recommendation [Re: rowin4] #1784321
03/27/15 05:57 PM
03/27/15 05:57 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
OD 833s
Re: Blowproof Clutch Housing Recommendation [Re: GTX MATT] #1784322
03/27/15 06:19 PM
03/27/15 06:19 PM
rowin4 Offline
rowin4  Offline
So the original poster is going to drop in a Hemi and use that piece of crap OD transmission. They wouldn't hold the torque of a 318 . Didn't they have a aluminum case with a small output shaft? I think I have one with the main shaft twisted off.
