ATF in 4 spd. #178372
12/29/08 08:41 PM
12/29/08 08:41 PM
pacific northwest
W
wings471 Offline OP
wings471  Offline OP
W
pacific northwest
I have a fresh rebuilt A-833 that has 85w gear oil in it. The synchros don't seem to be engaging as well as I think they should. Will it make enough of a difference if I drain the gear oil and replace it with ATF. I have been told the synchros will grab better and that ATF is what was originally in the units from the factory. Thanks..ever-so for your input.
Re: ATF in 4 spd. [Re: wings471] #178373
12/29/08 09:02 PM
12/29/08 09:02 PM
Kirkland, Washington
Pacnorthcuda Offline
Use a GL-4 rated gear oil, not ATF, not GL-5. my $.02
Re: ATF in 4 spd. [Re: Pacnorthcuda] #178374
12/29/08 09:20 PM
12/29/08 09:20 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
The newer OD trannies did come with ATF
Re: ATF in 4 spd. [Re: Pacnorthcuda] #178375
12/29/08 09:29 PM
12/29/08 09:29 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Re: ATF in 4 spd. [Re: Michael] #178376
12/29/08 10:54 PM
12/29/08 10:54 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Back in the day ATF was recomended in 4spds esecially in cold climates. I used it in mine with no problems. Dave
Re: ATF in 4 spd. [Re: wings471] #178377
12/30/08 08:43 AM
12/30/08 08:43 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
ATF will shift much better than gear oil and was the factory fill in most A833 applications. Gear oil was put in them because people complained about gear rattle in neutral.
Another choice is to use Roayl Purple, Redline or Penzoil manual transmission fluid. I have had the Penzoil Syncromesh Fluid in my A833 for about 20k miles now. It works even better than the ATF and provides better lubrication than ATF.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: ATF in 4 spd. [Re: dgc333] #178378
12/30/08 09:51 AM
12/30/08 09:51 AM
Davenport, IA
70shaker Offline
70shaker  Offline
Davenport, IA
Another vote for the Pennzoil Synchromesh. My trans shifts much better than it did with gear lube.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: ATF in 4 spd. [Re: quickd100] #178379
12/30/08 09:55 AM
12/30/08 09:55 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
IIRC there was a bulletin to use ATF in a 4 speed
Shifts better in the cold
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: ATF in 4 spd. [Re: VCODE] #178380
12/30/08 03:00 PM
12/30/08 03:00 PM
Minnesota
69Y2RT Offline
69Y2RT  Offline
Minnesota
30wt motor oil or synchromesh mopar part# 4874465
1969 Coronet R/T Y2 Y2 P6X X9 V8X 1967 Satellite 383 4speed
Re: ATF in 4 spd. [Re: VCODE] #178381
12/30/08 04:55 PM
12/30/08 04:55 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
If you read the svc bulletins is says recommended in cold weather.They did not come with ATF originally as some believe.They were filled with Multipurpose 90 weight gear oil.Read your owners manual.
Re: ATF in 4 spd. [Re: I go fast] #178382
12/30/08 05:39 PM
12/30/08 05:39 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
Well the owners manual for my 68 Barracuda makes no mention of what type of oil goes in the A833 just give capacities. However, the service manual I have states the A833 uses ATF and there is a note: "NOTE: If gear noise or rattle is experienced with the A833, SAE 90 gear oil maybe used in place of the ATF."
I have seen (but don't have a copy) TSBs that basically say the same thing to replace the ATF with gear oil if the customer is complaining of gear noise.
So, yes the factory did put ATF in A833's. Maybe not all years but certainly in some.
Re: ATF in 4 spd. [Re: dgc333] #178383
12/30/08 06:44 PM
12/30/08 06:44 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
You only read the specifications,its in the care and maintenance section.
Re: ATF in 4 spd. [Re: I go fast] #178384
12/30/08 07:35 PM
12/30/08 07:35 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
When I was first married we lived on the Iron Range in Minn., worked in the mines. It got real cold up there sometimes. I was driving my '69 383 4-spd RR, it was the only car I had at the time. My tranny had 80-90 in it. I got off work and it was -48 (that's not the wind chill either OZ). Car was plugged in and it reluctantly started but every time I tryed to let the clutch out it would kill the motor. I sat there for 20 minutes with my foot on the clutch before I could get it to move. After that I went to ATF, no more cold weather problems. Dave
Re: ATF in 4 spd. [Re: quickd100] #178385
12/30/08 09:29 PM
12/30/08 09:29 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Most people don't recommend it, but I've been using ATF in my 81 short bed since I started driving it back in 2000 cause it was already in it. Haven't had any issues with it.
Moparlee
Re: ATF in 4 spd. [Re: Michael] #178386
12/30/08 10:14 PM
12/30/08 10:14 PM
gtx-guy Offline
gtx-guy  Offline
Re: ATF in 4 spd. [Re: gtx-guy] #178387
12/31/08 04:32 AM
12/31/08 04:32 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I use RedLine MTL (manual Trans Lube.)
Quote fron web page:
http://www.redlineoil.com/products_gearlubricants.asp?categoryID=7
"This 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity) is designed for use in manual transmissions and transaxles. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting."
Re: ATF in 4 spd. [Re: I go fast] #178388
12/31/08 08:55 AM
12/31/08 08:55 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Not in my manual. I went an pulled it out and went through it.
Like I have said twice before over the years mopar has spec'd gear oil and ATF in the A833. So, pick the lube you are comfortable with.
Re: ATF in 4 spd. [Re: dgc333] #178389
12/31/08 11:01 AM
12/31/08 11:01 AM
MO
cdp Offline
cdp  Offline
MO
Contact Jamie Passon at Passon Performance. I understand he is very helpful and a manual transmission expert. He posts here sometimes.
Re: ATF in 4 spd. [Re: wings471] #178390
12/31/08 12:31 PM
12/31/08 12:31 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I have been using this for a couple of summers and seems to work great
Re: ATF in 4 spd. [Re: TOMRR] #178391
12/31/08 01:48 PM
12/31/08 01:48 PM
McGregor,Iowa 52157
500ciDuster Online content
500ciDuster  Online Content
McGregor,Iowa 52157
I know the O.D trannys used ATF but didn't think they every used it in anything that had any power, I would think it would heat up but I guess most of the new stuff uses thin oil.
