lifting body to install engine from below #1783717
03/19/15 04:07 PM
03/19/15 04:07 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
This worked OK, to remove the engine but as you can see, the cherry picker's legs are in the way.
To get the engine back in, I was going to make an extension out of angle iron to get the cherry picker out away from the body. I was going to bolt some angle iron to the bumper mounts and then a piece of angle iron in between those to lift against. I've seen people do this before.
I need a recommendation on what size and thickness of angle iron to get. 1 1/2" wide? 2" wide? 1/8" thick? 1/4" thick? Any suggestions? Thanks
Re: lifting body to install engine from below [Re: burdar] #1783718
03/19/15 04:16 PM
03/19/15 04:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I perched the car up on jackstands, wheeled the engine/suspension/cherry picker back underneath and hooked back up.
Re: lifting body to install engine from below [Re: DaytonaTurbo] #1783719
03/19/15 04:29 PM
03/19/15 04:29 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: lifting body to install engine from below [Re: JMCFAN] #1783720
03/19/15 04:39 PM
03/19/15 04:39 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
http://store.uscartool.com/uni-lift-unibody-front-end-lifting-tool.html
That's basically what I want to do but I'm going to use angle iron. I just want a recommendation of what size to use. I used a spare set of bumper brackets to install the engine in my Challenger. I've seen people use angle iron before.
Re: lifting body to install engine from below [Re: burdar] #1783721
03/19/15 04:44 PM
03/19/15 04:44 PM
Manitoba, Canada
Manitoba, Canada
You can use just about anything. I have the front end off my satellite right now, fenders, hood, engine, trans, suspension and all. If I grab onto the front rad support I can lift the car up by hand.
Re: lifting body to install engine from below [Re: burdar] #1783722
03/19/15 04:48 PM
03/19/15 04:48 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd say 2"X 1/8"thick will do the job. Maybe 1.750" angle might be OK. I would use 2" myself.
Re: lifting body to install engine from below [Re: DaytonaTurbo] #1783723
03/19/15 04:51 PM
03/19/15 04:51 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I just don't know how strong angle iron is. Is 1/8" thick strong enough if I'm going to make the arms roughly 30" long?
Thanks Gary...
Re: lifting body to install engine from below [Re: burdar] #1783724
03/19/15 05:11 PM
03/19/15 05:11 PM
Manitoba, Canada
Manitoba, Canada
2" x 1/8" would be plenty IMO. At 30" I would not worry.
Re: lifting body to install engine from below [Re: DaytonaTurbo] #1783725
03/19/15 05:23 PM
03/19/15 05:23 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Wishing you the best of luck with the install, Burdar...
Re: lifting body to install engine from below [Re: ebodyseast] #1783726
03/19/15 05:38 PM
03/19/15 05:38 PM
CA
crackedback Offline
crackedback  Offline
CA
2x2 .125 angle
2x2 .125 square tube
2 bolts/nuts
Drill 6 holes
I had to lift the engine and car with this set up because of the engine/car angle wouldn't allow it to settle at K frame. Long bolts run in, picked up, more blocks under pan. No problems at all.
Re: lifting body to install engine from below [Re: crackedback] #1783727
03/19/15 05:41 PM
03/19/15 05:41 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Perfect, thanks everyone!
Re: lifting body to install engine from below [Re: crackedback] #1783728
03/19/15 08:51 PM
03/19/15 08:51 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
2x2 .125 angle
2 bolts/nuts
Drill 6 holes
[image]http://img.photobucket.com/albums/v655/crackedback/70%20Dart%20340%20EK2/Engineinstall.jpg[/i
This is a nice install.Inexpensive and easy to make.Good job.
Re: lifting body to install engine from below [Re: burdar] #1783729
03/19/15 09:56 PM
03/19/15 09:56 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I think the boom on mine must slide out further than the one you have. I've done two...one in a B Body and one in an A with no trouble. Other thing I noticed is my dolley is about 6 or 8" higher. I guess that allows it to fit between the legs without touching the K-frame. No pics on this computer to share...
...FAFO...
Re: lifting body to install engine from below [Re: skicker] #1783730
03/19/15 10:12 PM
03/19/15 10:12 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I think I used 1/4 but I can check when I get home Saturday. 2 pieces coming off the bumper bolts (both bolts) with a piece going across with 2 bolts on each side. Not the best picture but you get the idea how they were turned.
Careful, your character's showing!
Re: lifting body to install engine from below [Re: mopar346] #1783731
03/19/15 10:13 PM
03/19/15 10:13 PM
mopar346 Offline
mopar346  Offline
I gotta learn to take better pictures.
Re: lifting body to install engine from below [Re: mopar346] #1783732
03/19/15 10:20 PM
03/19/15 10:20 PM
mopar346 Offline
mopar346  Offline
I have better ones that wont post. PM me your e-mail if you want them.
Re: lifting body to install engine from below [Re: mopar346] #1783733
03/19/15 10:47 PM
03/19/15 10:47 PM
mr norms avenue
5571 Offline
5571  Offline
mr norms avenue
I have a four post lift, I was thinking of doing the install with that, lowering the car over it. I can see how you can get access to the K frame bolts at ground level, but how are you guys getting to holding up the trans? When you have to raise the car to get the trans brace? Wont the engine tilt back on the motor mounts and hit the firewall?
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
Re: lifting body to install engine from below [Re: 5571] #1783734
03/20/15 12:00 AM
03/20/15 12:00 AM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
I put my engine and trans in from the bottom. Looks like Burdars garage may be a little different then mine though. I jus happened to pick up a 2500 pound atv winch new in the box for $20.00 at a garage sale. Bolted it to a 2x8 piece of ash, supported the roof rafters/joist with 2x4's to the floor. used another 2x4 between the frame rails under the radiator area and hoisted away.. Worked very well. I used 2x6s stacked on a set of snowmobile dollies and strapped engine and trans down to the dollies with a ratchet straps. I had engine and trans in in about 15 minutes. Kevin
71 gtx.....
Re: lifting body to install engine from below [Re: sleddinfool] #1783735
03/20/15 12:02 AM
03/20/15 12:02 AM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
Another. Kevin
71 gtx.....
Re: lifting body to install engine from below [Re: 5571] #1783736
03/20/15 12:09 AM
03/20/15 12:09 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
US Cartools
Check these out. Yes, not cheap, but convenient and they work (safely). I am a vendor for them (same prices as going direct) and I sell a lot of them, so far every customer loves them.
