motor swap...parts and plan #1783293
03/19/15 02:09 AM
03/19/15 02:09 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Some of you may remember my truck that I did the roller paint job on. Its a 318 auto with stock TBI system still in place. I actually need to verify 727 vs 904. Can I tell by the pan shape or just the rail numbers?
Anywho, I want to take the mild 360 that I pulled from my sig car, and put it in the truck with a carb. What are the parts needed and plan that I should follow to get this complete? I have the complete motor with a good functioning Eddy 600, a stock ignition setup (dizzy, orange box etc...) I know I need a truck 360 oil pan, I can use spacers on the drivers side motormount to make them work. I'll need the aftermarket flexplate in order to run the converter thats already on the trans. A fuel pressure regulator to protect the carb from the trucks electric fuel pump. Anything else I need to look at. Anything that I need to do as it pertains to the trucks computer?
Any help is appreciated
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: motor swap...parts and plan [Re: roe] #1783294
03/19/15 11:27 AM
03/19/15 11:27 AM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
Trans ID....
Thread on torqueflites on the B-Bodies only website :linky
The rest someone else will have to answer. Good luck!
John
Re: motor swap...parts and plan [Re: SattyNoCar] #1783295
03/19/15 11:57 AM
03/19/15 11:57 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I saved the pic to my files, thanks
Re: motor swap...parts and plan [Re: roe] #1783296
03/19/15 12:40 PM
03/19/15 12:40 PM
dogdays Offline
dogdays  Offline
The computer runs, among other things, the charging system. You'll need voltage regulator and associated wiring, IIRC.
R.
Re: motor swap...parts and plan [Re: dogdays] #1783297
03/19/15 02:37 PM
03/19/15 02:37 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
oil pickup tube to match the truck oil pan...
Re: motor swap...parts and plan [Re: dogdays] #1783298
03/19/15 10:57 PM
03/19/15 10:57 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
R.
Is there no way to hook the alternator into the existing electrical system and have it function correctly?
Re: motor swap...parts and plan [Re: roe] #1783299
03/20/15 10:41 AM
03/20/15 10:41 AM
scratchnfotraction Offline
Roe, does it have a voltage regulator on the firewall?
if not you can splice into the harness to add it.
same with the intake fuel pump, you can splice it to run with key and use regulator/return line for the carb.
it keeps the under hood harness intact and looking un molested/hacked up that way.
my self, I always get a 82-86 wire harness untape it,remove what I don't need and retape it. not that hard to swap out the complete wire harness underhood /indash.
just taped my 86 harness back up for the 82w350 next.
Re: motor swap...parts and plan [Re: scratchnfotraction] #1783300
03/24/15 01:31 AM
03/24/15 01:31 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Ok, im gonna see if I can overcome my fear of electrical, maybe even develop a new skill. Going to start looking for an '86 @ the j/y to pull the underhood and under dash harnesses from to swap over to myt ruck.
Wish me luck
roe
Re: motor swap...parts and plan [Re: roe] #1783301
03/24/15 02:41 AM
03/24/15 02:41 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have seen several trucks running around with car pans on them, even pulled one to swap an oil pump one time and it went in and out with no problem. It might should be swapped but you do not need to swap it.
As for the trans, it should most likely be an A-500 or 518. Very few TBI motors ever got a 3 speed.
Re: motor swap...parts and plan [Re: roe] #1783302
03/24/15 10:27 AM
03/24/15 10:27 AM
Wish me luck
roe
I will get you some pics of my harness spred out so you can see it and use for reference.
only part I ever have trouble with is the door switch..getting them out with out cutting the wire is my headache. so I cut and leave a pigtail to splice them back together.
Re: motor swap...parts and plan [Re: scratchnfotraction] #1783303
03/24/15 08:39 PM
03/24/15 08:39 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
My 1988 D100 with a TBI 318 and long bed had the 999 transmission(junky version of the 904 for fuel economy)
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: motor swap...parts and plan [Re: scratchnfotraction] #1783304
03/25/15 12:02 AM
03/25/15 12:02 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Thanks a lot for the offer on the pics, that will help me a bunch.
I checked and the trans is a 904. Not sure if its original or not.
Re: motor swap...parts and plan [Re: roe] #1783305
03/25/15 01:06 PM
03/25/15 01:06 PM
dogdays Offline
dogdays  Offline
The A999 transmission was better than a A904, built with more clutch disks, etc.
It also has the lower First gear IIRC 2.74, over the 2.45 regular 904 First.
They started being made in the mid '70s, according to my old Direct Connection chassis book.
The A904, A998 and A999 were made in the same case, so one would have to check the number on the pan rail to see what it exactly is.
R.
