Page 3 of 3 1 2 3
Re: checking for hidden delay box [Re: MR_P_BODY] #1782380
03/20/15 12:29 AM
03/20/15 12:29 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
If he had something that changed his time package it would be the only way to beat your perfect package. Maybe something to change the time difference in the tree, in effect slowing your side down.
Re: checking for hidden delay box [Re: cudaman1969] #1782381
03/20/15 12:37 AM
03/20/15 12:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I never said we had a perfect package... but if I beat
him on the tree he came up with a dead on with a zero
and I had a 2.. wasnt only me either... but it finally
came out... that was 2 weeks later.. one of the guys
spilled the beans after Bader had a talk
Re: checking for hidden delay box [Re: MR_P_BODY] #1782382
03/20/15 01:07 AM
03/20/15 01:07 AM
fredericksburg,va
fredericksburg,va
Sounds like what some guy was doing a long while ago, had some high frequency box that would wreck havoc with the ignition system so the engine ran bad. He did it at the starting line and was easy to catch him using it. I imagine it would have been less obvious down the track at the end. It worked very well against the solid plug wires everyone was using at that time.
Re: checking for hidden delay box [Re: cudaman1969] #1782383
03/20/15 01:19 AM
03/20/15 01:19 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Wouldn't it be easier to time the big end since everyone is watching the starting line....It would be easy to hide a small relay & timer that was set to a couple hundredths below your dial in and turned on the rev limiter at that exact time on the big end. No one would be likely to hear it down track as well and it would give the driver time to switch it off if they wanted too...
Curious, what did they find with the guy at Norwalk?
Re: checking for hidden delay box [Re: Dragula] #1782384
03/20/15 11:18 AM
03/20/15 11:18 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
Maddy Innovations. they used to have a web page. now you can so what they did with the grid ignition box.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: checking for hidden delay box [Re: kissmyaspen] #1782385
03/20/15 12:13 PM
03/20/15 12:13 PM
Minn
SportF Offline
SportF  Offline
Minn
You are right Dustin, and I don't think folks realize how this can foul up racing. Check out Gary Hairfield on the west coast. In either 2010 or 2011 he was track champ at 3 (three!) different tracks. Dialing an 8.04 at 1/8 mile at 100 mph, he would stay at that dial no matter how the night temps changed at Barona (San Diego). At the same time, I was running 7.30 at 95 mph (this is pro class).
DJ Detloff was another racer out there with the same set up, both these guys running 08 or 09 Corvettes. I don't know if they programmed the stock computer, or if aftermarket, the results were the same. That is, never change the dial all night long, always run the same number. Yes, they cut good lights, but when you see the same guys wining time after time its discouraging.
Out there you have some Mustang racers banging gears and trying to compete, its not worth the trip.
NHRA, you better get a handle on this or start a class for slew rates, but keep this stuff the heck out of non-electronics!!!!!!!!!
Re: checking for hidden delay box [Re: MR_P_BODY] #1782386
03/20/15 01:53 PM
03/20/15 01:53 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
I won't beat the horse but yes Bader found out how they were winning. And it was shown to him.
Yep... I commend the Baders for what they did..
those are good people
Baders were forced to make something happen before major happened.
Re: checking for hidden delay box [Re: cudasteve68] #1782387
03/20/15 02:09 PM
03/20/15 02:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they were... but they could have said nothing
and looked the other way.... but they didnt.. if
they didnt do anything it would have hurt their
business and they run a good track and try to keep
things on a even keel
Re: checking for hidden delay box [Re: MR_P_BODY] #1782388
03/20/15 05:50 PM
03/20/15 05:50 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
I am just saying that things were very ugly when things came to ahead. From what I know first hand there were more then 12. Many of them pulled the stuff when rumors started about the Matty Boxes being used. I know of a car that changed hands a few times that won an IHRA National ET Championship that still has brackets that a Matty Box & a delay box will bolt up to that was not part of the dozen.
Re: checking for hidden delay box [Re: MR_P_BODY] #1782389
03/20/15 06:29 PM
03/20/15 06:29 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Its already been said......a guy who REALLY wants to cheat will and there is not much you can do about it. Aside from having a VERY experienced, large, capable tech crew. Then how many want to sit in a long tech line for a weekly bracket race. It could take a LONG time to REALLY check a car closely. Why do you think many NHRA classes have "spec" parts. Simply makes it easier for tech. You plug in to the ignition box and look what it can do. 7531 boxes are not allowed in many classes. You can change the sticker, but as soon as they plug to it, they KNOW. But with todays electronics, the ability to do lots of things is there. If you choose to run "no box", you can pretty much assure yourself that SOMEBODY is cheating. You have several choices. One is do what you do and not worry about everyone else. Two, join the fray and be sneaky yourself. Three, run the Pro class, or four.......stay home.
Monte
Re: checking for hidden delay box [Re: Monte_Smith] #1782390
03/20/15 06:42 PM
03/20/15 06:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
I hear ya Monte... we raced with the guys cheating
(not knowing they were)but we kept trying to get better..
when we raced the one guy we did take home some money
that night but we didnt win
Re: checking for hidden delay box [Re: MR_P_BODY] #1782391
03/30/15 12:12 AM
03/30/15 12:12 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Just because a guy doesnt change his dial doesnt mean he's cheating. I RARELY change my dial. There are multiple reasons why and they have nothing to do with cheating.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: checking for hidden delay box [Re: Irun5snd8th] #1782392
03/30/15 09:09 AM
03/30/15 09:09 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Big motor, big tire cars will rarely change much, especially on alcohol.
Re: checking for hidden delay box [Re: Irun5snd8th] #1782393
03/30/15 01:36 PM
03/30/15 01:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
exactly,we had the division 2 director come ask to inspect my sons Jr Dragster at a race one time. somebody complained we had a delay box in it I am serious
Page 3 of 3 1 2 3
