1990 Caravan 3.3 liter, No Start, Flash Code 55 #178216
12/29/08 06:38 PM
12/29/08 06:38 PM
Fort DODGE, Ioway
O
origcharger Offline OP
O
Fort DODGE, Ioway
Likely culprit(s) for the code 55 on this 3.3?
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: origcharger] #178217
12/29/08 06:45 PM
12/29/08 06:45 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
55 is end of message. Do you have spark? Fuel pressure?
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: NITROUSN] #178218
12/29/08 07:57 PM
12/29/08 07:57 PM
St.Clair Shores, Mich
bryansgarage Offline
Check the secondary braided ground strap from the neg. battery terminal to the block. My 95 Caravan broke/rotted and had a no start condition.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: bryansgarage] #178219
12/29/08 08:40 PM
12/29/08 08:40 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Check the crank sensor. In fact, replace the crank sensor. Whether it needs it or not. They are NOTORIOUS for going bad. Its cheap and extremely easy to do. They wont always set a code.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: NITROUSN] #178220
12/29/08 09:10 PM
12/29/08 09:10 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
First things first, this is where you need to start.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: rrunner] #178221
01/01/09 01:41 PM
01/01/09 01:41 PM
Fort DODGE, Ioway
O
O
Fort DODGE, Ioway
Yea, trying to take a shortcut through the key board in a comfortable chair.
We have no spark.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: origcharger] #178222
01/01/09 01:54 PM
01/01/09 01:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Could also be the cam sensor in the distributor.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: stumpy] #178223
01/01/09 03:25 PM
01/01/09 03:25 PM
Fort DODGE, Ioway
O
O
Fort DODGE, Ioway
There is a cam sensor but there is no distributor.
This van was parked and took a headlamp fracturing bump in the drivers front corner and has not started since. Since the ECM is located in that area I believe I will check all connections there and then possibly try that crankshaft sensor.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: origcharger] #178224
01/03/09 02:20 PM
01/03/09 02:20 PM
Fort DODGE, Ioway
O
O
Fort DODGE, Ioway
Ok, no spark, has momentary power at the B+ terminal at the coil as per the manual and then momentary power again while cranking. I had the ECM disconnected and now it has a flash code of 12, no 12 is listed in the manual I am using. Once again its a 1990 3.3 Caravan but my only 3.3 manual is for a 93 Acclaim.
The thing is everything seems to be intermittant, once I detected constant power at the coil B+ while cranking, I then reconnected things and it cranked like the timing was off, fired and ran poorly till it died. Now nothing again, any ideas??? Any spots in harness that may be prone to issues?
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: origcharger] #178225
01/03/09 02:35 PM
01/03/09 02:35 PM
N
N
A 93 acclaim should be a 3.0 which is completely different.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: NITROUSN] #178226
01/03/09 03:04 PM
01/03/09 03:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think 12 means battery or power was disconnected.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: NITROUSN] #178227
01/03/09 09:53 PM
01/03/09 09:53 PM
Fort DODGE, Ioway
O
O
Fort DODGE, Ioway
The manual has a 3.3 - 3.8 section. It also has a 3.0 and a four cylinder section. It covers several differant letter designated Chrysler autos.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: origcharger] #178228
01/03/09 11:25 PM
01/03/09 11:25 PM
N
N
So its not a factory FSM.
Re: 1990 Caravan 3.3 liter, No Start, Flash Code 55 [Re: NITROUSN] #178229
01/04/09 12:15 AM
01/04/09 12:15 AM
Fort DODGE, Ioway
O
O
Fort DODGE, Ioway
It is a FSM, I should have said its a manual set we got that covered a 93 Acclaim we had, rather than imply that it was a specifically only for an Acclaim.
