Throttle cable #1781536
03/16/15 11:00 PM
03/16/15 11:00 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I need to replace my throttle cable. When they ask for length is it the cable length or jacket length they need. Will the Lokar cables hook up to the stock petal?
Thanks....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Throttle cable [Re: D-50] #1781537
03/17/15 01:10 AM
03/17/15 01:10 AM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
It's cut to fit (aka cut cable and jacket (not in that order hahaha)) so order it a bit long and you should be good to go. Used there kickdown cable and it worked great.
