Turn signals cut ignition? #1781134
03/16/15 07:03 AM
03/16/15 07:03 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I have a problem that's getting worst with my 70 Barracuda, it has had a very intermittent miss & as strange as it sounds it is mostly when I have either left or right turn signal going either at idle or highway speed it seems to cut the ignition when I use the turn signals! I'm wondering if I have either a crook earth or a poor power feed maybe? This car has run fine for years & there has been no repair or modification to the wiring in the last few years that caused this problem. The car is a factory 383 auto car that has had a Chrysler electronic ignition fitted about 10 years ago & ran perfectly fine until a couple of months ago.
Any ideas?
Re: Turn signals cut ignition? [Re: nz383man] #1781135
03/16/15 11:54 AM
03/16/15 11:54 AM
Aye mate, Yes that is a strange one . More info on the miss: it misses slightly all the time but gets aggravated when using the signals? If not all the time then is it at part (minimal) throttle, WOT or?. I'm thinking we gotta deal with the miss first. & I'd check the voltage drops at the coil/ecu etc and clean ALL terminals/connections & also see what your charging/running voltage is. that'll get us started
Re: Turn signals cut ignition? [Re: RapidRobert] #1781136
03/16/15 12:53 PM
03/16/15 12:53 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
sounds like there may be some bare wires for the turn signal switch in the steering column.
1981 Dodge D150 360 auto
Re: Turn signals cut ignition? [Re: RapidRobert] #1781137
03/16/15 04:00 PM
03/16/15 04:00 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I think the miss is only when the signals are on & it seams to have developed into almost an engine cut & it will do it at idle or when passing on the highway. I started cleaning terminals last night & it was a bit late to run the car when I was finished so I'll check the voltages tonight after work, Thanks
Re: Turn signals cut ignition? [Re: basketcase] #1781138
03/16/15 04:03 PM
03/16/15 04:03 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
It was a new unit fitted 10 years or so ago & the car hasn't done too many miles but I'll pull the column to bits tonight & look for rubbing/bare wires, Thanks
Re: Turn signals cut ignition? [Re: nz383man] #1781139
03/17/15 06:08 PM
03/17/15 06:08 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Look at the wiring harness by the bulkhead connector also. I had the same problem with my 70 Road Runner and found that the harness had worn thru over the years and was grounding at the firewall.
Nautilus Racing-
Re: Turn signals cut ignition? [Re: Chris2581] #1781140
03/18/15 06:41 AM
03/18/15 06:41 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I found the fuse holders were quite rusty & didn't look to be making good contact so I took them all apart cleaned & greased them as well as the bulkhead connectors & my problem seems to have gone away.
I have a car run this weekend so I'll give it a good run on Friday to make sure it is all good.
Driving home from the last trip out the car ran real bad at low revs & idle so I pulled the top of the factory AVS & found one of the floats had sunk. Easy fix as I have plenty of spares, adjusted the float level & drop, assembled carb & running well again.
