E body convertible top well cover. #1780678
03/15/15 04:16 PM
03/15/15 04:16 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
I am putting the metal strip on the back of the rearseat that holds the cover for the top well. When I bought my seats they were already recovered so I can't see the holes in the frame to mount the metal strip. Is there an easy way to line the strip up with the holes without poking through the seat vinyl until I get lucky? Don't want a bunch of punctures in the seat cover. Also, what is the correct screw for this? Thanks.
Re: E body convertible top well cover. [Re: 70cudaMD] #1780679
03/16/15 10:28 AM
03/16/15 10:28 AM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
If you slip your hand inside the rear seat back you can feel the holes once you get one started you should be all set.
Re: E body convertible top well cover. [Re: 340swing] #1780680
03/16/15 10:25 PM
03/16/15 10:25 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
I was able to find wholes in the seatback frame but they don't line up with the wholes in the retainer strip. frame was stripped and painted so I think the holes may have paint/filler in them. I assume it just uses sheetmetal screws right into the seat frame. Thanks.
Re: E body convertible top well cover. [Re: 70cudaMD] #1780681
03/16/15 11:11 PM
03/16/15 11:11 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
see if this helps
Re: E body convertible top well cover. [Re: 340swing] #1780682
03/16/15 11:12 PM
03/16/15 11:12 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
2
Re: E body convertible top well cover. [Re: 70cudaMD] #1780683
03/17/15 12:48 AM
03/17/15 12:48 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Hope that is the case but just so you know someone may have mixed it with a B-body convertible strip.
They are the same length and style except holes are in a different location than E-body strip.
Re: E body convertible top well cover. [Re: mccannix] #1780684
03/17/15 11:29 PM
03/17/15 11:29 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
Thanks, looks like I may have a strip for a B body.
