`68 Satellite Deconstruction #1780637
03/15/15 04:12 PM
03/15/15 04:12 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Some pictures of my 68` as I blast it.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: `68 Satellite Deconstruction [Re: 6bblFLASH] #1780638
03/15/15 04:26 PM
03/15/15 04:26 PM
N.E. Ohio
N.E. Ohio
Re: `68 Satellite Deconstruction [Re: 6bblFLASH] #1780639
03/15/15 04:27 PM
03/15/15 04:27 PM
N.E. Ohio
N.E. Ohio
2
Re: `68 Satellite Deconstruction [Re: 6bblFLASH] #1780640
03/15/15 04:29 PM
03/15/15 04:29 PM
N.E. Ohio
N.E. Ohio
3
Re: `68 Satellite Deconstruction [Re: 6bblFLASH] #1780641
03/15/15 04:30 PM
03/15/15 04:30 PM
N.E. Ohio
N.E. Ohio
Re: `68 Satellite Deconstruction [Re: 6bblFLASH] #1780642
03/15/15 04:32 PM
03/15/15 04:32 PM
N.E. Ohio
N.E. Ohio
Only a couple pin-holes about 1/8th" in the floor and thats it.
Re: `68 Satellite Deconstruction [Re: 6bblFLASH] #1780643
03/15/15 05:09 PM
03/15/15 05:09 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Clean car.
Sheldon
Re: `68 Satellite Deconstruction [Re: 6bblFLASH] #1780644
03/16/15 04:20 AM
03/16/15 04:20 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What media and equipment did you use to blast it? Looks great!
Re: `68 Satellite Deconstruction [Re: RTSrunner] #1780645
03/16/15 07:58 AM
03/16/15 07:58 AM
N.E. Ohio
N.E. Ohio
Thanks.
I've been putting off tearing it apart for a few years.
The thing is pretty much original EXCEPT for the drive train.
I'm using a Harbor Freight pressure pot and a homemade gun that uses 3/32 soda tips and a ball valve instead of a trigger.
Using "play-sand" from Lowe's.
I've done quite a bit of blasting at home over the years and this is by FAR the best I've had it work.
