MSD 7AL-2 boxes #178034
12/29/08 03:24 PM
12/29/08 03:24 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
My father-In-Law has a a 7AL-2 part # 42626, which comes with a MSD Coil Pro Power. I looked on the Web site for info, but all I found was the 7AL-2 Plus, which is probably a updated version. This box was serviced By MSD years ago, but has been self ed since then.
So here is a few questions.
I assume this is the correct coil for this box? Can this box be run on the street? I don't think so, but maybe with a different compatible coil?
Are these boxes dependable, and reliable?
Rapid
Re: MSD 7AL-2 boxes [Re: Bob_Coomer] #178035
12/29/08 03:34 PM
12/29/08 03:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rapid
Basicly I dont think you can run that box on the
street, it says that you need to run the pro power
coil and they say the pro power coil shouldnt be
run on the street or for extended periods of time.
Thats the same box I run in my racecar
Re: MSD 7AL-2 boxes [Re: MR_P_BODY] #178036
12/29/08 03:36 PM
12/29/08 03:36 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
good box though
Re: MSD 7AL-2 boxes [Re: The Avg. Valiant] #178037
12/29/08 04:00 PM
12/29/08 04:00 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
yes they are good boxes, I run them in the Dart. I run that coil on both my dragster and doorcar.
Re: MSD 7AL-2 boxes [Re: MR_P_BODY] #178038
12/29/08 04:21 PM
12/29/08 04:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Rapid
Gotta look at which coil I am running, but I have been running a 7AL-2 on the street since '96, and it was in the car when I got it. All I can say is, you need a good set of wires, or you will spit half your teeth out if you get hit with it....It is far better than the 6AL, and can tolerate a richer fuel mixture without fouling plugs.
Re: MSD 7AL-2 boxes [Re: Dragula] #178039
12/29/08 05:35 PM
12/29/08 05:35 PM
Rock Springs
Rock Springs
Rapid
That's great news, I can get this thing for a song & a Dance...
If you would check to see what coil your running...I was thinking a Blaster II was compatible, and I just might get away with it on the street
I spent about 30 minutes on hold with MSD, and finally just hung up...
Re: MSD 7AL-2 boxes [Re: Bob_Coomer] #178040
12/29/08 05:40 PM
12/29/08 05:40 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i ran the mallery coil ending with 440 for a few yrs with my msd 7al-2 but not on the street.the mallery is for extended use run time.
Re: MSD 7AL-2 boxes [Re: blownzoom440] #178041
12/29/08 06:05 PM
12/29/08 06:05 PM
Dragula Offline
Dragula  Offline
The coil is an MSD blaster 2. Both have been in the car since I bought it, and I have had the unlucky misfortune of being lit up by both, and the 6AL feel like half the zap of a 7AL...Just my two cents for what its worth.
Re: MSD 7AL-2 boxes [Re: blownzoom440] #178042
12/29/08 06:06 PM
12/29/08 06:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The 7AL-2 will be fine for street use, you just need a constant duty coil, which the Pro-Power is not. Use the Pro-Power HVC coil, part number 8251.
Monte
Re: MSD 7AL-2 boxes [Re: Monte_Smith] #178043
12/29/08 06:24 PM
12/29/08 06:24 PM
ELYRIA,OH
ELYRIA,OH
Monte
i was told by a tech at the track that the Pro-Power HVC coil, part number 8251 is the same just american made as the pro power.i did not check the winding ratio or other details.
Re: MSD 7AL-2 boxes [Re: Bob_Coomer] #178044
12/29/08 06:43 PM
12/29/08 06:43 PM
AndyF Online content
AndyF  Online Content
The MSD website lists six different coils as compatable with the 7AL-2. Of the six, the 8252 is probably the best one for street duty but other might be just as good. The 8207 is another street/strip coil that is compatable with the 7AL-2.
The 7AL-2 can be purchased a lot cheaper from Mopar Performance than from MSD. I think the discount is about 40% when puchased as a MP part number which is huge.
I'm currently running the 7AL-2Plus with the 8261 on my dyno mules. The 8261 coil can probably be used as a welder in a pinch so you really do not want to grab a plug wire while you're standing in a puddle.
Re: MSD 7AL-2 boxes [Re: AndyF] #178045
12/29/08 06:48 PM
12/29/08 06:48 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Do you happen to have a part number? I can't seem to find it. It looks to me like Mopar perf. only has the 6AL version.
Re: MSD 7AL-2 boxes [Re: mopowers] #178046
12/29/08 06:53 PM
12/29/08 06:53 PM
I don't remember the MP number but just go to the Mancini website and look under ignitions. The MP version is $350 while the MSD part number is $560.
While we're on the subject, here is a coil bracket that I made for the HVC style coils. This bracket bolts to the end of the cylinder head. I also did a bracket for the Pro Power coil but I'll have to dig around for that picture.
Re: MSD 7AL-2 boxes [Re: AndyF] #178047
12/29/08 07:02 PM
12/29/08 07:02 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
That bracket is slick.
It's amazing to me that the same product can have two totally different prices.
Re: MSD 7AL-2 boxes [Re: blownzoom440] #178048
12/29/08 08:20 PM
12/29/08 08:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
I have no idea about that. All I know is what the catalog says. It says that the 8251 is compatible and is made for extended use. There are other compatible part #s as well, but the 8251 was about the cheapest. The HVC Andy mentioned is nearly 200 bucks.
Monte
Re: MSD 7AL-2 boxes [Re: mopowers] #178049
12/29/08 11:22 PM
12/29/08 11:22 PM
Here is the bracket for the 8201 coil. The 8201 coil is dinky compared to the HVC unit.
Re: MSD 7AL-2 boxes [Re: Monte_Smith] #178050
12/30/08 01:16 AM
12/30/08 01:16 AM
Southington Ct.
turbobitt Online content
turbobitt  Online Content
Southington Ct.
Monte
I agree because I have been using the marine version 7ML-2 on extended use with no issues but using the high vibration blaster coil. I was concerned about the extended use and contacted MSD before buying and they assured me it would be OK.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
