Lowering a 1990 dodge ramcharger #1780402
03/15/15 02:17 AM
03/15/15 02:17 AM
jacksonville,FLORIDA
slammedR/T Offline OP
OK, I read the lowering thread about the van lca's and i will be doing this. But have some questions about the rear as none of the rear parts have been clearly explained. Now I'm going 3" of drop with the van LCA's and stock springs whihc is all my Father wants on the front. So I will want to drop the rear 2" to keep that slight rake he wants. Now since a flip kit will be too much drop, what are you guys using for the rear for only 2"-3" of drop? I figured longer shackles but which ones do I need? I can't find any that are 73-93 dodge ram specific, and figure some chebbies ones would work but what year/make chebbie ones I need?
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Lowering a 1990 dodge ramcharger [Re: slammedR/T] #1780403
03/15/15 06:04 PM
03/15/15 06:04 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Drop rear shackles for 88-98 Chevy. $40 at local parts store. Good for 1-2" drop.
Re: Lowering a 1990 dodge ramcharger [Re: 76dodgeboy] #1780404
03/15/15 06:06 PM
03/15/15 06:06 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
If its not low enough you can flip the front hanger for another 1-2"
Re: Lowering a 1990 dodge ramcharger [Re: 76dodgeboy] #1780405
03/15/15 06:27 PM
03/15/15 06:27 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
the real question here, is WHY?
Re: Lowering a 1990 dodge ramcharger [Re: volaredon] #1780406
03/15/15 06:49 PM
03/15/15 06:49 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Because race truck...
Re: Lowering a 1990 dodge ramcharger [Re: slammedR/T] #1780407
03/15/15 08:33 PM
03/15/15 08:33 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Don't want to get into a pissing contest with Dodgeboy, but the '88 up Chevy long hangers I have here use metric sized bolts, slightly larger than the original Dodge ones, so I am THINKING (I know, dangerous) that longer shackles for the earlier, '73 to '87 style GM pickups might be the right size.
Though, I haven't done it.
I had my leaves de arched instead ... not saying it's the right or only way, just how I did it.
It takes gasoline to interest me.
Re: Lowering a 1990 dodge ramcharger [Re: volaredon] #1780408
03/16/15 02:23 AM
03/16/15 02:23 AM
Because the truck will look better when he cruises it on the weekends
racemagnum
Re: Lowering a 1990 dodge ramcharger [Re: volaredon] #1780409
03/16/15 02:29 AM
03/16/15 02:29 AM
SW Missouri
moparmandjh Offline
moparmandjh  Offline
SW Missouri
Because it's his, not yours.
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
Re: Lowering a 1990 dodge ramcharger [Re: moparmandjh] #1780410
03/16/15 09:29 PM
03/16/15 09:29 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Moparlee
Re: Lowering a 1990 dodge ramcharger [Re: Robbins] #1780411
03/17/15 04:36 AM
03/17/15 04:36 AM
Photo of the Ramcharger in question;
racemagnum
Re: Lowering a 1990 dodge ramcharger [Re: slammedR/T] #1780412
03/19/15 05:09 PM
03/19/15 05:09 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Sweet looking Ramcharger...I am going to be pulling all of the wide black trim off my race '86 Ramcharger (weight saving measure, LOL)and I am fairly certain it is the same as your '90, so if you need the piece for your pass door let me know
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Lowering a 1990 dodge ramcharger [Re: Robbins] #1780413
03/19/15 06:18 PM
03/19/15 06:18 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
bingo !
Re: Lowering a 1990 dodge ramcharger [Re: Polarapete] #1780414
03/19/15 07:33 PM
03/19/15 07:33 PM
He wants to remove all his trim also, but I told him to replace it in the mean time. Heck what kinda money you want for it, I might get it for a present for him and put it back on myself.
racemagnum
Re: Lowering a 1990 dodge ramcharger [Re: slammedR/T] #1780415
03/20/15 04:30 AM
03/20/15 04:30 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am missing the one off the driver side and I am almost certain the one on the pass side is good. I will check in the AM and send you a PM. I can wrap it in cardboard and ship it FedEx. Send me your address after I PM the status of the part.
2008 Honda Element
Re: Lowering a 1990 dodge ramcharger [Re: slammedR/T] #1780416
03/20/15 11:23 AM
03/20/15 11:23 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I likie the blue!
Moparlee
Re: Lowering a 1990 dodge ramcharger [Re: Robbins] #1780417
03/27/15 01:09 PM
03/27/15 01:09 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I'd do a flip & slide the rear hanger down on the frame till desired height in the rear
