Lowering a 1990 dodge ramcharger
#1780402
03/15/15 01:17 AM
03/15/15 01:17 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
OK, I read the lowering thread about the van lca's and i will be doing this. But have some questions about the rear as none of the rear parts have been clearly explained. Now I'm going 3" of drop with the van LCA's and stock springs whihc is all my Father wants on the front. So I will want to drop the rear 2" to keep that slight rake he wants. Now since a flip kit will be too much drop, what are you guys using for the rear for only 2"-3" of drop? I figured longer shackles but which ones do I need? I can't find any that are 73-93 dodge ram specific, and figure some chebbies ones would work but what year/make chebbie ones I need?
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Lowering a 1990 dodge ramcharger
[Re: volaredon]
#1780406
03/15/15 05:49 PM
03/15/15 05:49 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
the real question here, is WHY?
Because race truck...
[Re: slammedR/T]
#1780407
03/15/15 07:33 PM
03/15/15 07:33 PM
Posts: 1,357 central Florida
VL21
central Florida
Don't want to get into a pissing contest with Dodgeboy, but the '88 up Chevy long hangers I have here use metric sized bolts, slightly larger than the original Dodge ones, so I am THINKING (I know, dangerous) that longer shackles for the earlier, '73 to '87 style GM pickups might be the right size. Though, I haven't done it. I had my leaves de arched instead ... not saying it's the right or only way, just how I did it.
It takes gasoline to interest me.
[Re: volaredon]
#1780408
03/16/15 01:23 AM
03/16/15 01:23 AM
slammedR/T
Because the truck will look better when he cruises it on the weekends
[Re: Robbins]
#1780411
03/17/15 03:36 AM
03/17/15 03:36 AM
slammedR/T
Photo of the Ramcharger in question;
[Re: Robbins]
#1780413
03/19/15 05:18 PM
03/19/15 05:18 PM
Posts: 35,246 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Because it's his, not yours.
bingo !
[Re: Polarapete]
#1780414
03/19/15 06:33 PM
03/19/15 06:33 PM
slammedR/T
Sweet looking Ramcharger...I am going to be pulling all of the wide black trim off my race '86 Ramcharger (weight saving measure, LOL)and I am fairly certain it is the same as your '90, so if you need the piece for your pass door let me know
He wants to remove all his trim also, but I told him to replace it in the mean time. Heck what kinda money you want for it, I might get it for a present for him and put it back on myself.
