Re: Torsion bar mounts repairs
[Re: wunderwagon]
#1780137
03/15/15 12:13 PM
03/15/15 12:13 PM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
Check with Auto Rust Technicians. They make that type of unit plus other repair pieces. They are out of Delaware or Rhode Island if I remember correctly.
Carl Kessel
[Re: wunderwagon]
#1780140
03/19/15 11:24 PM
03/19/15 11:24 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have a 69 c body with typical rust belt rust at the torsion bar rear mount. Is there any interchangeably with other body styles frame rails torsion bar mounts and transmission x piece. I would like to use a commercial doubler plate like those made by auto rust technicians. However there are none available, other alternatives are plate fab or Donner cars. Hope this is posted in the correct place
Can you find out how much different the other model Auto Rust Tech mounts are from what you need for the C-body?
I have some E-body Auto Rust Tech torsion bar mount caps out in the garage if you need some dimensions. It may just need a cut and a new piece spliced in to make it work. Not ideal, but potentially an option nonetheless.
[Re: DaytonaTurbo]
#1780142
03/20/15 09:51 PM
03/20/15 09:51 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Trouble is the frame rails are shot too. Unless your resto shop is good at fabricating such things, you really need another sub frame.
I have mechanical Aptitude. I can screw up anything.
