Re: WOW. Larry Dixons Top Fuel wreck today.
[Re: carcrazyguy]
#1779850
03/14/15 06:27 PM
03/14/15 06:27 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Car had a new front half put on. And was a 2010 chassis.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: jcc]
#1779853
03/14/15 08:27 PM
03/14/15 08:27 PM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A combo of toooo much wing on the front and rear of the car ?
Not in my book, the wings were doing what they were supposed to, applying DF, which allowed the available HP to accelerate the car, causing the front end to try and lift, enough to the point the chassis failed. Its chassis failure.
It just flat buckled in the front 1/3 of the chassis.
[Re: jcc]
#1779854
03/14/15 08:48 PM
03/14/15 08:48 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Doc called it right, if it didn't have more wing than the chassis could handle it wouldn't have failed.
[Re: B5 Bee]
#1779855
03/14/15 09:00 PM
03/14/15 09:00 PM
Posts: 22,728 Bitopia
jcc
Bitopia
Or if it has less HP, or less tire, or less traction, or testosterone, or less etc
[Re: Rhinodart]
#1779858
03/15/15 01:08 AM
03/15/15 01:08 AM
1967dartgt
Hilltown Pa
The chassis was from 2010, it was wore out. The hp strain over powered the metal fatigue and it snapped the chassis.
[Re: Rhinodart]
#1779859
03/15/15 01:16 AM
03/15/15 01:16 AM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Same thing happened to Larry also at Memphis when he was driving for Snake when Lahaie was crew chief. Almost identical except in Memphis, lugs sheared and tire shot up, had to have been 300 feet in the air, came down 12 rows over in the west-side parking lot, bounced at least 4 times before it disappeared. Can't remember the exact year, think it was 2001, Tony also had a bad crash on Saturday where the wing collapsed and sent him over the wall, (different from the blowover above)really scary cause Tony was tumbling in the cage right next to the engine tumbling. https://www.youtube.com/watch?v=-AnL9FLlvZY
[Re: 1967dartgt]
#1779860
03/15/15 01:22 AM
03/15/15 01:22 AM
Posts: 982 western pennsylvania
b1dartsport
That old chassis was tweaked in the high end by down force on every run and it finally failed.
[Re: 1967dartgt]
#1779861
03/15/15 01:22 AM
03/15/15 01:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats all I think it was.. it was old
[Re: carcrazyguy]
#1779862
03/15/15 01:47 AM
03/15/15 01:47 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Front downforce and rear downforce create center lift...
The chassis will arch , but it is definitely not caused by lift as I understand the term. The rear wheels are trying to drive past the fronts and the front wing provided enough downforce to prevent a wheel stand and the tubes arched to the point of failure. Dixon said in a post crash interview that the car only had 50 passes on it. He seemed O.K. , but Man.......what a ride ! I always liked him as a driver , so I hope he can bounce back and return to the track. I don't know if Vandergriff has a spare car or not.
[Re: lewtot184]
#1779863
03/15/15 07:41 AM
03/15/15 07:41 AM
Posts: 304 Enfield, Ct
Moe
Enfield, Ct
looks like the chromemoly tube broke.
Chromemoly can't break?
