WOW. Larry Dixons Top Fuel wreck today. #1779846
03/14/15 05:41 PM
03/14/15 05:41 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: pittsburghracer] #1779847
03/14/15 05:45 PM
03/14/15 05:45 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Holy Cow!!! That was crazy, hope he's alright. What the heck causes that?
Randy
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: Dartin] #1779848
03/14/15 05:52 PM
03/14/15 05:52 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
A combo of toooo much wing on the front and rear of the car ?
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: dOc …] #1779849
03/14/15 06:00 PM
03/14/15 06:00 PM
Texas
carcrazyguy Offline
carcrazyguy  Offline
Texas
Front downforce and rear downforce create center lift...
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: carcrazyguy] #1779850
03/14/15 06:27 PM
03/14/15 06:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Car had a new front half put on. And was a 2010 chassis.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: 1967dartgt] #1779851
03/14/15 06:45 PM
03/14/15 06:45 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Jack "300 Bowl" Ostrander had the same thing happen at the Gators 20 years ago. The car broke in the center from the load between the front and rear wings.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: dOc …] #1779852
03/14/15 08:16 PM
03/14/15 08:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not in my book, the wings were doing what they were supposed to, applying DF, which allowed the available HP to accelerate the car, causing the front end to try and lift, enough to the point the chassis failed. Its chassis failure.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: jcc] #1779853
03/14/15 08:27 PM
03/14/15 08:27 PM
gregsdart Offline
gregsdart  Offline
It just flat buckled in the front 1/3 of the chassis.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: jcc] #1779854
03/14/15 08:48 PM
03/14/15 08:48 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Doc called it right, if it didn't have more wing than the chassis could handle it wouldn't have failed.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: B5 Bee] #1779855
03/14/15 09:00 PM
03/14/15 09:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Or if it has less HP, or less tire, or less traction, or testosterone, or less etc
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: jcc] #1779856
03/14/15 09:27 PM
03/14/15 09:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
looks like the chromemoly tube broke.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: lewtot184] #1779857
03/15/15 12:46 AM
03/15/15 12:46 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Same thing happened to Tony Schumacher in 2000.
https://www.youtube.com/watch?v=I966mNsrOb0
JB Rhinehart, Realist
A-Body's RULE!
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: Rhinodart] #1779858
03/15/15 01:08 AM
03/15/15 01:08 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The chassis was from 2010, it was wore out. The hp strain over powered the metal fatigue and it snapped the chassis.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: Rhinodart] #1779859
03/15/15 01:16 AM
03/15/15 01:16 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Same thing happened to Larry also at Memphis when he was driving for Snake when Lahaie was crew chief. Almost identical except in Memphis, lugs sheared and tire shot up, had to have been 300 feet in the air, came down 12 rows over in the west-side parking lot, bounced at least 4 times before it disappeared. Can't remember the exact year, think it was 2001, Tony also had a bad crash on Saturday where the wing collapsed and sent him over the wall, (different from the blowover above)really scary cause Tony was tumbling in the cage right next to the engine tumbling.
https://www.youtube.com/watch?v=-AnL9FLlvZY
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: 1967dartgt] #1779860
03/15/15 01:22 AM
03/15/15 01:22 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
That old chassis was tweaked in the high end by down force on every run and it finally failed.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: 1967dartgt] #1779861
03/15/15 01:22 AM
03/15/15 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats all I think it was.. it was old
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: carcrazyguy] #1779862
03/15/15 01:47 AM
03/15/15 01:47 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The chassis will arch , but it is definitely not caused by lift as I understand the term.
The rear wheels are trying to drive past the fronts and the front wing provided enough downforce to prevent a wheel stand and the tubes arched to the point of failure.
Dixon said in a post crash interview that the car only had 50 passes on it.
He seemed O.K. , but Man.......what a ride !
I always liked him as a driver , so I hope he can bounce back and return to the track.
I don't know if Vandergriff has a spare car or not.
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: lewtot184] #1779863
03/15/15 07:41 AM
03/15/15 07:41 AM
Enfield, Ct
Moe Offline
Moe  Offline
Enfield, Ct
Chromemoly can't break?
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: Moe] #1779864
03/15/15 08:40 AM
03/15/15 08:40 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wow lucky!
Re: WOW. Larry Dixons Top Fuel wreck today. [Re: 1967dartgt] #1779865
03/15/15 09:49 AM
03/15/15 09:49 AM
NC
440Jim Offline
440Jim  Offline
NC
Does this indicate that NHRA needs to require thicker tubing in that area? Reduce stress to increase fatique life? I don't think a little extra weight is going to hurt the speed of that class.
