Need 1969 Coronet R/T Radiator for 4-Speed car? #177969
12/29/08 02:08 PM
12/29/08 02:08 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Is there anyone reproducing radiators fot the 1969 Coronet R/T with a 4-speed?
When I bought the car it had a bad radiator and it had the automatic transmission fittings.
Currently, I have an aluminum radiator in the car, but I am lookin for sonething that looks more correct.
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 451Mopar] #177970
12/29/08 02:57 PM
12/29/08 02:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Glen-Ray Radiators
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 451Mopar] #177971
12/29/08 11:28 PM
12/29/08 11:28 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
Hi,
I have a 055. needs redone.
Kevin
HEMI,S ARE FOREVER!!!
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 451Mopar] #177972
12/30/08 12:20 AM
12/30/08 12:20 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 451Mopar] #177973
12/30/08 12:27 PM
12/30/08 12:27 PM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
You should have a 2949054 26" radiator and it will have cooler ports in the lower tank. From the factory, they were plugged for 4-speed cars. Check your old radiator, it could have been the correct one, if not, contact Glen Ray as suggested above.
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: Paul] #177974
12/30/08 07:49 PM
12/30/08 07:49 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
The 055 was the standard radiator for the 4 speed with 3.54 gears. The 4:10 gears got the 054 radiator. The 055 is not that hard to find as it was used in A/C cars too.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 69CoronetRT] #177975
12/30/08 10:29 PM
12/30/08 10:29 PM
BFE
blue67440's Offline
blue67440's  Offline
BFE
Doug,
The parts list shown doesn't differentiate between A33 and A34 cars for rads. - how do you know that 4:10's get the 054 and not the 055?
I believe you are right, just wanting to know more.
blue
XP29L72 A833 in 881 XP29L72 A727 in 881
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: blue67440's] #177976
12/31/08 01:52 AM
12/31/08 01:52 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Doug,
blue
One way is through broadcast sheets. Here are an A33 and an A32 GTX. (I'll keep looking for a legible D21 A34 sheet)
Seeking:
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 69CoronetRT] #177977
12/31/08 03:17 AM
12/31/08 03:17 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Thanks everyone,
Bob from Glen Ray sent me a PM. I am just waiting to hear back on pricing and options.
I am not going the full restoration route with the car. I know it is fairly rare (1 of 99 4-speed convertibles built in 1969), but it is not numbers matching. It currently has a 1970 440 HP engine and I think the 833 trans had a vin stamped in it that decoded to a 1969 or 1970 GTX?
I have an extra 1969 440 engine that I am going to rebuild into a 505" stroker with the 440 source stealth heads. I haven't decided on an intake or exhaust yet, but I was thinking of maybe running a six-pack and maybe the manifolds so it would look fairly stock. If I can afford it I may install a Keisler 5-speed too.
Anyhow, I am looking for a stock looking / fitting radiator that can cool the 505" engine, although it will probbably have less than 550 HP.
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 451Mopar] #177978
12/31/08 03:32 AM
12/31/08 03:32 AM
BFE
blue67440's Offline
blue67440's  Offline
BFE
451,
You never mentioned if your R/T is an A33 or A34 car, but if the pic. in your original post is the car in question, it looks like you have manual drum brakes, which would indicate the A33 Track Pack, A34 includes mandatory power discs. After seeing that pic I would lean towards the 2949 055 radiator.
blue
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: blue67440's] #177979
12/31/08 03:48 AM
12/31/08 03:48 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Yes, the car was an A33 Track Pack with 3.54:1 Dana 60. It also was a non-fresh air car, but some previous owner install a 4.10 Dana 60, and the N96 fresh air system even though I believe it is from a 1970 model?
It has the 11"x3" manual drum brakes, and I updated them with the 1970 self adjusting brake hardware.
The car is a nice 20-foot car, but everything needs redone. Right now it is a decent car to cruse around in and take to shows, but the valve seals in the 440 must be shot as it is burning oil. I am planning on doing a slow multi-year restoration on the car, saving the body work for last so I can enjoy driving the car each summer.
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 69CoronetRT] #177980
12/31/08 08:12 PM
12/31/08 08:12 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Doug, without a broadcast sheet a 055 or 054 COULD be correct although the 054/max cooling is the option. Im putting the 054/max cooling package in my R/T since I have no sheet and an Az car could easily have been ordered with it, beside I need the extra cooling
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: AZ_A12_BEE] #177981
12/31/08 08:26 PM
12/31/08 08:26 PM
BFE
blue67440's Offline
blue67440's  Offline
BFE
After Doug posted the broadcast pic's last nite, I went to my file folders and found a scan of 2 69 charger R/T buildsheets I have, both are A33 & 440 cars and both are coded "55" for the radiator.
I wish I could scan them, but apparently our scanner is on the fritz, anyway, I would love to see a sheet for an A33 car coded for a "54" rad.
Doug or 6bblgt, ya got any thoughts?
blue
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: blue67440's] #177982
12/31/08 08:36 PM
12/31/08 08:36 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Doug "as usual" is correct. A A33 car would have the 055 rad. And another poster went on to say the car has manual drums so it can't be an A34 car that inturn would dictate the 054 rad... Very cool car by the way
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: AZ_A12_BEE] #177983
12/31/08 08:57 PM
12/31/08 08:57 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Dave, I understand why you would go that way but the Max cool package with 054 was not an option that could be ordered by itself. It came as a part of another option group such as trailer towing or the gear packages. Max Cool was also standard with the Hemi and A12 cars.
However...never say never. I would like to see a BS from an A33 car that shows 054 instead of 055.
Happy New Year to all
Seeking:
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: blue67440's] #177984
12/31/08 09:00 PM
12/31/08 09:00 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
blue
All the Charger and Coronet R/T and GTX A33 sheets I have show 55.
Seeking:
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 69CoronetRT] #177985
12/31/08 09:08 PM
12/31/08 09:08 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Doug, can you show me where the max cooling could not be ordered as a stand alone package, it did have its own designation, N51? I cant see why it could not have been ordered by itself.
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: AZ_A12_BEE] #177986
12/31/08 09:11 PM
12/31/08 09:11 PM
BFE
blue67440's Offline
blue67440's  Offline
BFE
Better yet Doug do the sheets you have for the A33 cars show N51 and N65?
blue
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: AZ_A12_BEE] #177987
01/01/09 12:57 PM
01/01/09 12:57 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Dave, you're asking me to prove a negative and that's not possible.
Not all build codes, such as N51, are options that can be ordered by a customer.
If N51 was an option that could be ordered, it would show up in the data book, the salesman book, pricing updates, window stickers and the options and accessories report with cost as appropriate.
I can think of a couple of other build codes, such N97 (noise reduction), that show up on the BS but were not options that could be ordered. The incusion of the components indicated by the build code were triggered by other factors in the construction or sale of the car.
N65 yes N51 no
Happy New Year.
Seeking:
Re: Need 1969 Coronet R/T Radiator for 4-Speed car? [Re: 69CoronetRT] #177988
01/01/09 01:14 PM
01/01/09 01:14 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
N51 does show up on my A12 Bees wholesale dealer invoice as a separate item less fan
