Best clay to use for piston/valve check? #1778957
03/13/15 04:58 PM
03/13/15 04:58 PM
Penna
70satelliteguy Offline OP
Penna
What kind to ask for? Where to get?
Thanks mike
Re: Best clay to use for piston/valve check? [Re: 70satelliteguy] #1778958
03/13/15 05:08 PM
03/13/15 05:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I use light springs and feeler gauges to check mine but years ago I've used this. It can be bought easily at craft stores.
https://www.google.com/search?q=modeling+clay&ie=utf-8&oe=utf-8
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best clay to use for piston/valve check? [Re: pittsburghracer] #1778959
03/13/15 05:12 PM
03/13/15 05:12 PM
dogdays Offline
dogdays  Offline
Play Doh
R.
Re: Best clay to use for piston/valve check? [Re: dogdays] #1778960
03/13/15 06:35 PM
03/13/15 06:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Who cares, as long it it compresses and holds it shape. Nothin' technical about it ... plasticine from the dollar store !!
Re: Best clay to use for piston/valve check? [Re: 70satelliteguy] #1778961
03/13/15 11:03 PM
03/13/15 11:03 PM
Call the hobby stores till you find one that has a very small quantity of it cuz you dont need much & when done seal it in a small baggie so it stays moist/dont get hard. I'd think several lumps as big as your thumb or maybe a slight bit more would be plenty (enough to set in the valve reliefs)
Re: Best clay to use for piston/valve check? [Re: 70satelliteguy] #1778962
03/13/15 11:09 PM
03/13/15 11:09 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
I used .99 cent store silly putty.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Best clay to use for piston/valve check? [Re: 71autoxr] #1778963
03/14/15 12:19 AM
03/14/15 12:19 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Don't forget to grease or oil the surface so the clay doesn't stick to the valve and ruin the reading.
Re: Best clay to use for piston/valve check? [Re: 70satelliteguy] #1778964
03/14/15 06:54 PM
03/14/15 06:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Tape a couple of pieces of 1/8" solder around the valve relief...holds its shape and gives a more precision reading using a mic/calipers.
Re: Best clay to use for piston/valve check? [Re: John_Kunkel] #1778965
03/14/15 10:25 PM
03/14/15 10:25 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i've heard to use a tootsie roll, then pop it in the freezer, mic it, then eat it, seems like it would work just fine then you get a treat after.
Re: Best clay to use for piston/valve check? [Re: John_Kunkel] #1778966
03/14/15 10:26 PM
03/14/15 10:26 PM
ding ding ding I do believe we have a winna . John is the man. I'm gonna do it. I never did like that oily clay mess either
