24 Tooth Speedo Pinion Req'd
#1777698
03/12/15 05:42 AM
03/12/15 05:42 AM
Posts: 216 united kingdom
Simonic
united kingdom
My speedo reads slow.After checking the chart in the tech area of this forum I realize I need a 24 tooth pinion. I've looked at the normal parts outlets and nobody seems to supply one that small. Can any of you suggest a supplier for this part please?
Keeping the Bee Buzzin'
Re: 24 Tooth Speedo Pinion Req'd
[Re: Simonic]
#1777699
03/12/15 09:58 AM
03/12/15 09:58 AM
Posts: 1,487 STL
cdstl
STL
A&A Transmission in Indianapolis shows a 25 tooth as their smallest. You might have to settle for that.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cdstl]
#1777700
03/12/15 11:53 AM
03/12/15 11:53 AM
Posts: 13,584 md
mopars4ever
md
[Re: mopars4ever]
#1777701
03/12/15 12:31 PM
03/12/15 12:31 PM
Posts: 4,285 Ohio
64dodge572
Ohio
I do not currently have a 24T in stock, you need to call A&A. He has more parts than on his website.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: mopars4ever]
#1777702
03/12/15 12:35 PM
03/12/15 12:35 PM
RapidRobert
If you ain't already I would suggest "rollout" to confirm the exact tooth pinion you need (especially since you need a rare size). There also is a mini reduction gearbox the size of your fist that goes inline on the speedo cable to fine tune adjust the speed also. I have one but no pic at the moment.
[Re: RapidRobert]
#1777703
03/12/15 02:38 PM
03/12/15 02:38 PM
Simonic
united kingdom
Thank You for all the info gentlemen. I'll get started on this over the weekend
[Re: Stanton]
#1777707
03/14/15 01:51 PM
03/14/15 01:51 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
63 any gears for 65 back trannys are pricey.They are different than 66 up.Its even hard to find some.I know my 65s speedo is off but I know by how much so I just ajust the speed.Rocky
Chrysler Firepower
[Re: 63stabamatic]
#1777708
03/14/15 05:28 PM
03/14/15 05:28 PM
Posts: 4,727 Florida
BDW
FWIW, I could never find a gear for my pushbutton 65 trans and the adapter is very expensive. I went with a heads up display GPS speedometer Gtop HG100. There are a lot of GPS speedometers around to choose from. What's cool is you can change tires, gears, whatever, it doesn't care.
Got any more details? What's involved, cost, reception?
[Re: John_Kunkel]
#1777710
03/14/15 11:47 PM
03/14/15 11:47 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Speedometer - Free - Speed Limit Alert with Map, HUD and GPS Black Box Recorder by Stanislav Dvoychenko https://appsto.re/us/NmhqH.iGreat product. Free for basic, couple of bucks for upgrade. Perfect for checking out accuracy of speedo and odometer. The more teeth you have on your 'driven' gear on speedo cable, the slower your speedo reads compared to your actual true speed. The drive gear is the one on trans tail shaft. Contrary to op's thoughts, I believe you need a driven gear with fewer teeth, not more. When does the ground war begin?
