Rear Differential Question....... #1777244
03/11/15 07:41 PM
03/11/15 07:41 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I have a 70 Barracuda that I am moving the springs in 1" with a spring relocation kit.
My intention was to weld the new perches 1" in from the previous location. But like a lot of mopars my rear wheel clearance to the outer wheel housing is different from side to side. The difference is 1".
Can I take that difference out when welding in the new perches without any negative impact. It would mean moving the one perch in 1/2" and the other perch in 1 1/2".
Re: Rear Differential Question....... [Re: Finoke] #1777245
03/11/15 08:40 PM
03/11/15 08:40 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Why not just put a B body rear in it? Just bolts in
Re: Rear Differential Question....... [Re: scatpacktom] #1777246
03/11/15 08:45 PM
03/11/15 08:45 PM
dogdays Offline
dogdays  Offline
I don't see why you can't center the rear end in the car, but I'd hope you waited until the springs have actually been moved, then place the rear end. No telling if those spring hangers are even amounts from the sheetmetal.
R.
Re: Rear Differential Question....... [Re: scatpacktom] #1777247
03/11/15 09:08 PM
03/11/15 09:08 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Because I didn't know that trick 10 years ago when I bought the e body Dana.
Re: Rear Differential Question....... [Re: dogdays] #1777248
03/11/15 09:10 PM
03/11/15 09:10 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
R.
Good point. Will rehang the springs first on the off sets then measure again. Very good point.
Re: Rear Differential Question....... [Re: Finoke] #1777249
03/11/15 11:38 PM
03/11/15 11:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
The 1970 E bodys and 1971 B and E bodys are the same width on the Dana 60 As far as your body panels and wheel and tire fitment in the car differences, welcome to the wonderful world of mass produced muscle cars
Re: Rear Differential Question....... [Re: Cab_Burge] #1777250
03/11/15 11:55 PM
03/11/15 11:55 PM
CA
crackedback Offline
crackedback  Offline
CA
They are not the same length. 71-B's are about 1.5 inches wider than a 70-71 E rear.
Re: Rear Differential Question....... [Re: Finoke] #1777251
03/12/15 12:01 AM
03/12/15 12:01 AM
Make I'm missing something but it sounded to me like he would like to shift the axle over sideways (1/2" to split the 1" difference) to even out the wheel to fender clearance. If that ain't it just disregard this
Re: Rear Differential Question....... [Re: crackedback] #1777252
03/12/15 03:06 AM
03/12/15 03:06 AM
I'm under the impression the Dana 60 for both the E bodys and 1971 B bodys are 56 inches from the axle housing end to end on both and the axles are intercahngeable on both I've never heard any one say what your saying, never Have you seen or measured different?
Re: Rear Differential Question....... [Re: Cab_Burge] #1777253
03/12/15 03:27 AM
03/12/15 03:27 AM
CA
crackedback Offline
crackedback  Offline
CA
https://board.moparts.org/ubbthreads/show...e=5#Post4161878
Re: Rear Differential Question....... [Re: crackedback] #1777254
03/12/15 05:02 AM
03/12/15 05:02 AM
I stand corrected, thanks for the help
Re: Rear Differential Question....... [Re: RapidRobert] #1777255
03/12/15 07:50 AM
03/12/15 07:50 AM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Correct. I am Just trying to shift the rear left to right. I should have left out the spring relocation part in my question. Sorry to confuse everyone.
It makes no difference in my question except that is the real reason I am moving the spring perches.
Re: Rear Differential Question....... [Re: Finoke] #1777256
03/12/15 11:28 AM
03/12/15 11:28 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd install the springs, then center the rear.
Re: Rear Differential Question....... [Re: justinp61] #1777257
03/12/15 02:00 PM
03/12/15 02:00 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Will do, thx
