Anyone run a Pertronix Ignitor3 billet distributor? #1777198
03/11/15 06:53 PM
03/11/15 06:53 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I bought a Pertronix Ignitor3 billet distributor with built-in rev limiter for my BB 400 low deck block. I have Edelbrock RPM heads and the distributor is hitting the head enough that it won't go into the block straight enough to get into the oil pump drive-shaft. Nothing ever fits no matter how much ya spend.
I'd probably make a mess grinding the head.
And I really can't grind on this distributor in case I need to return it for some reason so I guess I need to decide on which one to grind. The distributor has a pretty beefy aluminum ring around it that's hitting the head. I may be able to grind it there, but it'd be a large area as I'm sure I'll have to turn it to adjust the timing.
I bought this for the rev limiter, it looks nice, and it's a simple 2 wire hook up that gets rid of quite a few wires, ECU, and ballast. I have the Ignitor3 coil also.
Just wondering if anyone is running this setup. Does it fit with stock heads?
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777199
03/11/15 07:13 PM
03/11/15 07:13 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Years ago I bought a MP distributor made by Accel. I had to significantly grind the 906 head for it to fit. So this does not surprise me.............
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: markz528] #1777200
03/11/15 07:28 PM
03/11/15 07:28 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I wonder how thick the Eddy head is right in the area where the dist hits? The heads are max wedge cnc ported if that matters.
I don't think it would take much sanding or grinding but I certainly don't want to take any chances.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777201
03/11/15 11:23 PM
03/11/15 11:23 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Just a thought..... But you could put a small block in it
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: B3422W5] #1777202
03/11/15 11:38 PM
03/11/15 11:38 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Don, I read that the Ignitor3 hits the firewall on a small Block so that would not work.
I'd love to buy something someday that actually fits!
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777203
03/12/15 12:13 AM
03/12/15 12:13 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Where I think you will need to grind seems like it has Plenty of meat there based on looking at my Eddies mounted on my engine. If you don't need much clearance to make the Dist fit, you should be fine.
If the clearance problem is at the heads front bolt bosses, there is Plenty of meat there. If the clearance problem is at the heads curvature behind the heads bolt bosses, there appears to be some thickness there as well. Would prefer to see the head off to view any water ports in that area if any for a better perspective.
If as you say, you don't need much to get clearance I think you would be fine on grinding the head.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: Sport440] #1777204
03/12/15 08:05 AM
03/12/15 08:05 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks Mike, I'm gonna call Pertronix today just to see if they've been down this road yet, then tonite after work I'll take a better look at it and try to see EXACTLY where it needs ground. I'd really rather massage the cylinder head in that area than to make the distributor non-returnable or un-sellable, although the plan is to keep it.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777205
03/12/15 10:56 AM
03/12/15 10:56 AM
an8sec70cuda Offline
Bob...I'd grind the head. That way you'll always have clearance no matter how much you have to adjust the distributor. Should be plenty of meat to grind away to get enough room...doesn't need much.
It's been a while, but I think I had to grind clearance on my Indy valve cover for the MSD billet distributor on my SR headed 440.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: an8sec70cuda] #1777206
03/12/15 01:19 PM
03/12/15 01:19 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Chip, that's what Pertronix said to do, he said they touch against some of the stock heads too. Now I'm gonna have to figure out how to do this w/o getting aluminum dust all over this waxer car!
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777207
03/12/15 04:32 PM
03/12/15 04:32 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Hey, I know waxers! Just buy a 9' X 12' plastic sheet from Lowe's or Home Depot. You'll find it in the paint department. Drape it over the engine bay, cut out a small hole, and tape the edges of the hole around the area you'll be grinding on.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: DusterDave] #1777208
03/12/15 06:20 PM
03/12/15 06:20 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I knew you'd show up at the word waxer Dave!!
That's a great idea, I'm gonna go do that right now and get this new ignition installed.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: DusterDave] #1777209
03/12/15 06:22 PM
03/12/15 06:22 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've ground two different 440s to get the Pertronix to fit, no problems. Cut a little and check, repeat till it fits. You may have to clearance the valve covers depending on which brand you use.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777210
03/12/15 11:29 PM
03/12/15 11:29 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Hopefully someone that ports Eddy RPM heads will chime in here and let me know how much meat is in the distributor area of these heads. I really removed alot of material today and it still was nowhere near fitting. I called Pertronix and he said they've seen guys grind an area of the distributor, they will still warranty the electrocics inside, just won't warranty the housing. So I ground on the distributor housing and it will now slide down and seat on the block but it won't turn to adjust timing, so I'm gonna have to grind on the head more, just need someone to make me feel better by saying that area of the head is super thick.
This setup is nice, billet aluminum, 2-wire hookup(and one power wire), adjustable rev limiter, good reliability.
But the fitment is a pain! And if I ever want to carry a spare it will have to be ground down also.
Valve covers seem to be fine so far.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777211
03/13/15 12:27 AM
03/13/15 12:27 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Can you show us a pic of the head where you needed to grind the most.
Whats better yet is you need to find a bud who has a Eddie head that you can look at from the under side into that closest water jacket.
But from comparing my mounted Eddie to a 906 the eddie has a Huge overhang towards the distributer.
My bet is you have Tons of room in that heads overhang to make that dist, fit.
If no one local has a eddie head to look at and compare, maybe a trip to Summit. Not sure if they have a Eddie head displayed or not.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: Sport440] #1777212
03/13/15 10:34 AM
03/13/15 10:34 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Mike just drill a hole in your Eddy head, measure material thickness, Weld hole up, post results here. Thanks!
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777213
03/13/15 12:15 PM
03/13/15 12:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Firecore fits perfect with no grinding
64 Plymouth Savoy
Dana 60
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: fourgearsavoy] #1777214
03/13/15 12:34 PM
03/13/15 12:34 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Hi Gus, I went with Pertronix just cuz it's simple, eliminates wiring, and has a built-in Rev limiter which I really needed. I didn't think I'd need a Rev limiter for this street car but this 500" max wedge Zings like a ticked-off small Block so I'm always afraid to play with the loud pedal.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777215
03/14/15 12:24 PM
03/14/15 12:24 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
That's ok, Bob, I forgive you. But we do have a rev-limiter for our ready to run. No biggie. It kills me that manufacturers don't design parts so you don't have to grind on thousands of dollar parts..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: sunroofgtx] #1777216
03/14/15 12:40 PM
03/14/15 12:40 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Rick do you have a link to your RTR with a rev limiter? When I went to your website there was no mention of a rev limiter for that distributor. That's the only reason I went with Pertronix. And yes it sucks to have to grind on a billet aluminum housing, it looks like crap but will be hidden against the head and I will polish it up.
Muscle Motors told me there's quite a bit of beef in that area of the head so I'm gonna take a little more off there too.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777217
03/14/15 12:43 PM
03/14/15 12:43 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Here it is but I still don't see a rev limiter mentioned.
https://www.customwiresets.com/product.php?productid=16287&cat=308&page=1
