Anyone run a Pertronix Ignitor3 billet distributor?
#1777198
03/11/15 06:53 PM
03/11/15 06:53 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I bought a Pertronix Ignitor3 billet distributor with built-in rev limiter for my BB 400 low deck block. I have Edelbrock RPM heads and the distributor is hitting the head enough that it won't go into the block straight enough to get into the oil pump drive-shaft. Nothing ever fits no matter how much ya spend. I'd probably make a mess grinding the head. And I really can't grind on this distributor in case I need to return it for some reason so I guess I need to decide on which one to grind. The distributor has a pretty beefy aluminum ring around it that's hitting the head. I may be able to grind it there, but it'd be a large area as I'm sure I'll have to turn it to adjust the timing. I bought this for the rev limiter, it looks nice, and it's a simple 2 wire hook up that gets rid of quite a few wires, ECU, and ballast. I have the Ignitor3 coil also. Just wondering if anyone is running this setup. Does it fit with stock heads?
Re: Anyone run a Pertronix Ignitor3 billet distributor?
[Re: ProSport]
#1777199
03/11/15 07:13 PM
03/11/15 07:13 PM
Posts: 4,274 Morrow, OH
markz528
Morrow, OH
Years ago I bought a MP distributor made by Accel. I had to significantly grind the 906 head for it to fit. So this does not surprise me.............
[Re: ProSport]
#1777203
03/12/15 12:13 AM
03/12/15 12:13 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I wonder how thick the Eddy head is right in the area where the dist hits? The heads are max wedge cnc ported if that matters. I don't think it would take much sanding or grinding but I certainly don't want to take any chances.
Where I think you will need to grind seems like it has Plenty of meat there based on looking at my Eddies mounted on my engine. If you don't need much clearance to make the Dist fit, you should be fine.
If the clearance problem is at the heads front bolt bosses, there is Plenty of meat there. If the clearance problem is at the heads curvature behind the heads bolt bosses, there appears to be some thickness there as well. Would prefer to see the head off to view any water ports in that area if any for a better perspective.
If as you say, you don't need much to get clearance I think you would be fine on grinding the head.
[Re: ProSport]
#1777205
03/12/15 10:56 AM
03/12/15 10:56 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Bob...I'd grind the head. That way you'll always have clearance no matter how much you have to adjust the distributor. Should be plenty of meat to grind away to get enough room...doesn't need much.
It's been a while, but I think I had to grind clearance on my Indy valve cover for the MSD billet distributor on my SR headed 440.
[Re: ProSport]
#1777210
03/12/15 11:29 PM
03/12/15 11:29 PM
ProSport
Akron, Ohio
Hopefully someone that ports Eddy RPM heads will chime in here and let me know how much meat is in the distributor area of these heads. I really removed alot of material today and it still was nowhere near fitting. I called Pertronix and he said they've seen guys grind an area of the distributor, they will still warranty the electrocics inside, just won't warranty the housing. So I ground on the distributor housing and it will now slide down and seat on the block but it won't turn to adjust timing, so I'm gonna have to grind on the head more, just need someone to make me feel better by saying that area of the head is super thick. This setup is nice, billet aluminum, 2-wire hookup(and one power wire), adjustable rev limiter, good reliability. But the fitment is a pain! And if I ever want to carry a spare it will have to be ground down also. Valve covers seem to be fine so far.
[Re: ProSport]
#1777211
03/13/15 12:27 AM
03/13/15 12:27 AM
Sport440
Canton, Ohio
Can you show us a pic of the head where you needed to grind the most. Whats better yet is you need to find a bud who has a Eddie head that you can look at from the under side into that closest water jacket. But from comparing my mounted Eddie to a 906 the eddie has a Huge overhang towards the distributer. My bet is you have Tons of room in that heads overhang to make that dist, fit. If no one local has a eddie head to look at and compare, maybe a trip to Summit. Not sure if they have a Eddie head displayed or not.
[Re: fourgearsavoy]
#1777214
03/13/15 12:34 PM
03/13/15 12:34 PM
ProSport
Akron, Ohio
Hi Gus, I went with Pertronix just cuz it's simple, eliminates wiring, and has a built-in Rev limiter which I really needed. I didn't think I'd need a Rev limiter for this street car but this 500" max wedge Zings like a ticked-off small Block so I'm always afraid to play with the loud pedal.
