Store Brake Lines #1776829
03/11/15 12:22 AM
03/11/15 12:22 AM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Anybody know why the tube ends are different sizes?
[img] [/img]
Re: Store Brake Lines [Re: clonestocker] #1776830
03/11/15 12:30 AM
03/11/15 12:30 AM
I've wondered about that too. Maybe not an app issue (they're the same except the back length of the fitting), maybe something on the assy line to keep em in order (a visual) as they go down the line
Re: Store Brake Lines [Re: clonestocker] #1776831
03/11/15 12:45 AM
03/11/15 12:45 AM
smyrna,tn
draginmopars Offline
smyrna,tn
using the longer fitting
on the wheel cylinder side
makes it easier to get a wrench on
due to the bleeder screw protruding from the wheel cylinder.
at the tee area there is more room
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Store Brake Lines [Re: draginmopars] #1776832
03/11/15 01:19 AM
03/11/15 01:19 AM
due to the bleeder screw protruding from the wheel cylinder.at the tee area there is more room
Makes real good sense
Re: Store Brake Lines [Re: RapidRobert] #1776833
03/11/15 02:12 AM
03/11/15 02:12 AM
Tucson, Arizona
Tucson, Arizona
Thx for the replies. The threads are the same that means you get two tries because the other end is AN.
[img] [/img]
