Re: Which automatic shifter are you using !!??
[Re: markz528]
#1776765
03/11/15 05:54 PM
03/11/15 05:54 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
I agree, as much as I love my Pro-Ratchet, a rear exit cable would be awesome. Although I did ditch the 5' cable for a 4' cable and that made life easier in my Duster. I also added a 3' heat sleeve for cheap from Summit for added protection.
[Re: markz528]
#1776770
03/11/15 06:47 PM
03/11/15 06:47 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I have a CSR shield and a front exit shifter. The hole in my floorboard is behind the rear of the shield...no problem there.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: MR_P_BODY]
#1776775
03/11/15 09:45 PM
03/11/15 09:45 PM
Posts: 13,226 aZLiViN
J_BODY
aZLiViN
I never cared for that PPP shifter... I could make that in my shop...
Talk is cheap.... Let's see you do it.
Maybe Ray can beta test it.
[Re: J_BODY]
#1776776
03/11/15 09:48 PM
03/11/15 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Why would I if I dont like it in the first place
[Re: megajoltman]
#1776779
03/11/15 10:22 PM
03/11/15 10:22 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
cheetah shifter here, but will go with the PPP shifter eventually.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
