Re: Which automatic shifter are you using !!??
[Re: markz528]
#1776765
03/11/15 05:54 PM
03/11/15 05:54 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I agree, as much as I love my Pro-Ratchet, a rear exit cable would be awesome. Although I did ditch the 5' cable for a 4' cable and that made life easier in my Duster. I also added a 3' heat sleeve for cheap from Summit for added protection.
[Re: markz528]
#1776770
03/11/15 06:47 PM
03/11/15 06:47 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I have a CSR shield and a front exit shifter. The hole in my floorboard is behind the rear of the shield...no problem there.
[Re: MR_P_BODY]
#1776775
03/11/15 09:45 PM
03/11/15 09:45 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I never cared for that PPP shifter... I could make that in my shop...
Talk is cheap.... Let's see you do it.
Maybe Ray can beta test it.
[Re: J_BODY]
#1776776
03/11/15 09:48 PM
03/11/15 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Why would I if I dont like it in the first place ![](/ubbthreads/images/graemlins/wave.gif)
[Re: megajoltman]
#1776779
03/11/15 10:22 PM
03/11/15 10:22 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
cheetah shifter here, but will go with the PPP shifter eventually.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
