Page 3 of 3 1 2 3
Re: Which automatic shifter are you using !!?? [Re: markz528] #1776765
03/11/15 05:54 PM
03/11/15 05:54 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree, as much as I love my Pro-Ratchet, a rear exit cable would be awesome. Although I did ditch the 5' cable for a 4' cable and that made life easier in my Duster. I also added a 3' heat sleeve for cheap from Summit for added protection.
Re: Which automatic shifter are you using !!?? [Re: ProSport] #1776766
03/11/15 06:11 PM
03/11/15 06:11 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
Quicksilver here. Hated it with a full manual valve body on the street. Cant wait to try out the transgo shift kit I installed over the winter.
Re: Which automatic shifter are you using !!?? [Re: skep419] #1776767
03/11/15 06:16 PM
03/11/15 06:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use the pistol grip Quarter Stick with a T/A Cheetah Forward Manual Valve Body on the street and LOVE the way it works!
Managing the reverse lockout can be a pain but it's not like I have to reverse often anyway.
I have, however, installed the TransGo TF-2 in a lot of transmissions I've built for myself and other people and it works really well if you don't want to shift all the time. Used in conjunction with the high rpm upshift governor it makes for a nice setup on the street!
Re: Which automatic shifter are you using !!?? [Re: GY3] #1776768
03/11/15 06:23 PM
03/11/15 06:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
PPP....Never had an issue and its rear cable entry...
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776769
03/11/15 06:35 PM
03/11/15 06:35 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Well I was going to put a B&M Pro Ratchet in my GTX build but now I am leaning towards the PPP. The rear exit is too good to pass up.
How do you even put a front exit cable with a CSR shield? I have a Cheetah in my race car with the rear entry and it is wonderful to have the rear entry, but the Cheetah is not a street shifter.
I burnt 1 shifter cable using the pro ratchet.. that
was the very first cable.. it was a bit short and I
didnt cover it.. I was being brave.. since then I
use a longer cable and I DONT use the heavy duty one..
they are a lot stiffer and harder to bend to clear
things... but I heat wrap it just to be sure... never
burnt up another... I'll wrap it just so I can use
the shifter I like... this cable has been in there
14 years now
Been there done that. But my question is with the CSR shield right up against the floor boards, isn't the location where the shifter cable goes through the floor be in the same spot as the CSR shield? Is it possible to use a front exit shifter with the CSR shield?
Re: Which automatic shifter are you using !!?? [Re: markz528] #1776770
03/11/15 06:47 PM
03/11/15 06:47 PM
an8sec70cuda Offline
I have a CSR shield and a front exit shifter. The hole in my floorboard is behind the rear of the shield...no problem there.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which automatic shifter are you using !!?? [Re: markz528] #1776771
03/11/15 06:50 PM
03/11/15 06:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
14 years now
I run that shield also.. I forget where the cable
goes through the firewall but its not far from the gas
pedal.. so its outside of the shield.. on the Rampage
I have the cable on top of the carpet(for now) but
if it runs a year with this routing I will put it
under the carpet.. IF it burnt the cable I didnt
want to have to lift the carpet.. but I figure by
1 year I should know.. so far so good
EDIT
I do have a black cover over it now... but it will
go under the carpet if its good
Re: Which automatic shifter are you using !!?? [Re: an8sec70cuda] #1776772
03/11/15 07:18 PM
03/11/15 07:18 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Great! Thanks! I have some time before I buy one so I will digest my options for a while.............
Re: Which automatic shifter are you using !!?? [Re: markz528] #1776773
03/11/15 07:32 PM
03/11/15 07:32 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I ran the csr shield on my 73 Dartsport with the Pro-ratchet shifter, no problems.
Re: Which automatic shifter are you using !!?? [Re: markz528] #1776774
03/11/15 07:45 PM
03/11/15 07:45 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I have put about 4500 miles on my car in the last few years with a cheetah shifter with a reverse valve body. I don't have any complaints.
68 Barracuda Formula S 340
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776775
03/11/15 09:45 PM
03/11/15 09:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I never cared for that PPP shifter... I could make
that in my shop...
Talk is cheap.... Let's see you do it.
Maybe Ray can beta test it.
Re: Which automatic shifter are you using !!?? [Re: J_BODY] #1776776
03/11/15 09:48 PM
03/11/15 09:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
that in my shop...
Why would I if I dont like it in the first place
Re: Which automatic shifter are you using !!?? [Re: J_BODY] #1776777
03/11/15 09:51 PM
03/11/15 09:51 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
The stock factory original console shifter. It still works good and I haven't worn it out yet.
Re: Which automatic shifter are you using !!?? [Re: Mr. T] #1776778
03/11/15 10:19 PM
03/11/15 10:19 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
PPP
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Which automatic shifter are you using !!?? [Re: megajoltman] #1776779
03/11/15 10:22 PM
03/11/15 10:22 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
cheetah shifter here, but will go with the PPP shifter eventually.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Which automatic shifter are you using !!?? [Re: slammedR/T] #1776780
03/11/15 10:45 PM
03/11/15 10:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the B & M Pro Stick. Dont cost alot and simple to use. Ron
Page 3 of 3 1 2 3
