Page 1 of 3 1 2 3
Which automatic shifter are you using !!?? #1776725
03/10/15 10:14 PM
03/10/15 10:14 PM
CA.
RAY1969CARS Offline OP
CA.
And why do you like it
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776726
03/10/15 10:18 PM
03/10/15 10:18 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
PPP nice positive engagement simple to use.
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776727
03/10/15 10:20 PM
03/10/15 10:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
B&M Pro Ratchet.... why... because it has NEVER missed
a shift
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776728
03/10/15 10:24 PM
03/10/15 10:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
a shift
Same here for the same reason.
I also have a T handle W/ a button for the line lock on it.
Re: Which automatic shifter are you using !!?? [Re: WILD BILL] #1776729
03/10/15 10:28 PM
03/10/15 10:28 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Im with Wild Bill and MR.P,
I run the B&M Pro Ratchet, and it is flawless after all these years.
But if i found a smoking deal on a PPP shifter, then i would buy it.
Re: Which automatic shifter are you using !!?? [Re: HEMIDARTS] #1776730
03/10/15 11:09 PM
03/10/15 11:09 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Im a Street / Strip guy.... using a B&M Quicksilver. Bought it because I liked the look. Found that I love the way it works and It's real solid feeling. Manual VB 727, so I'm up & down the gears all the time on the street, and I've never missed a shift
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776731
03/10/15 11:25 PM
03/10/15 11:25 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
a shift
Same here, for many years.
Re: Which automatic shifter are you using !!?? [Re: StealthWedge67] #1776732
03/10/15 11:26 PM
03/10/15 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Im a Street / Strip guy.... using a B&M Quicksilver. Bought it because I liked the look. Found that I love the way it works.
I put the same thing in my Rampage... sorry I didnt
put a Pro Ratchet in instead.. but I liked the looks
of the Quicksilver counsel
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776733
03/10/15 11:33 PM
03/10/15 11:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My street car has a Quick Silver which works excellent. But I prefer this.
Doug
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776734
03/10/15 11:35 PM
03/10/15 11:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Turbo Action Cheetah SCS.... It's been a hate/love relationship. It was a miserable POS with the reverse pattern gate. Easy to miss a shift or overshift, sloppy feel from N-1-2. This shifter is dependent on the "rooster" comb on the trans and has no built in detents. I recently swapped in a clean N trans brake, and changed the gate on the shifter. It is 100% better with the new gate..... but "unfortunately" a PPP clean N shifter w/t airshift came up for sale and I picked that up. No doubt, look in every serious race car these days....you'll find a PPP.
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776735
03/10/15 11:41 PM
03/10/15 11:41 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Reverse manual 727: I had a B&M Mega shifter, loved it but sold it for a Cheetah shifter...I could not get used to it, I'd get excited in the later rounds and pull it from 1st to 3rd, it was my problem, not the shifter, I'd pull instead of slap it to shift
Sold it and installed a B&M Pro Ratchet with a pistol grip and I love it, never missed a shift, but guess what? After watching my Go Pro in car vids...I slap it?
I'd say the best shifter depends on the guy shifting it. One size does not fit all.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Which automatic shifter are you using !!?? [Re: J_BODY] #1776736
03/10/15 11:56 PM
03/10/15 11:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The gate in my hand was the "reverse manual" pattern TA supplies. As you can see you had P at the top, R, over the stop to N, and then 1-2.....all three positions inline, you can see where this would cause issues. It was actually doing to 1-2 shift on it's own launching off the brake. The gate I installed is soooo much better. 1'st gear is at the stop, down to 2nd where it moves over ready for 3, and then you have to pull it over for the last N.
another point is the TA shifter being a gate shifter you still rely on the N safety in the trans. Most "ratchet" shifters give you the option of having the N safety feature run off a switch in the shifter itself.
Re: Which automatic shifter are you using !!?? [Re: J_BODY] #1776737
03/11/15 12:00 AM
03/11/15 12:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'll take this off the wall after the decoration novelty wears off and install it in the car this unit shifts soooo nice. Can't wait to give it a whirl!
Re: Which automatic shifter are you using !!?? [Re: J_BODY] #1776738
03/11/15 12:24 AM
03/11/15 12:24 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Re: Which automatic shifter are you using !!?? [Re: GY3] #1776739
03/11/15 12:38 AM
03/11/15 12:38 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
PPP
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776740
03/11/15 12:48 AM
03/11/15 12:48 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
a shift
. I agree same reason why I use one
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Which automatic shifter are you using !!?? [Re: WHITEDART] #1776741
03/11/15 12:57 AM
03/11/15 12:57 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
I have a hurst quarter stick(same as b&m pro ratchet) and a cheetah,i don't like the cheetah but I love the hurst, i'll probably end up swapping the cheetah out for another hurst
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776742
03/11/15 01:00 AM
03/11/15 01:00 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I also have the B&M Pro Ratchet
It's been in my car for 21 years and I never missed a shift
Re: Which automatic shifter are you using !!?? [Re: RV2] #1776743
03/11/15 10:02 AM
03/11/15 10:02 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Cheetah reverse pattern. I can see how making the accidental 1-2 shift could be a problem although it's never happened to me, and my car is slow enough not to worry about it happening on its own. It's smooth, easy, and reliable.
68 Barracuda Formula S 340
Re: Which automatic shifter are you using !!?? [Re: upnover] #1776744
03/11/15 10:03 AM
03/11/15 10:03 AM
an8sec70cuda Offline
Hurst 1/4 stick...b/c I hate ratchet shifters.
CHIP
'06 GMC 2500HD LBZ Duramax
Page 1 of 3 1 2 3
