Front ABS Sensor/Harness Replacement - '03 Ram #1776360
03/10/15 11:24 AM
03/10/15 11:24 AM
NE Iowa
Road_RunnerSteve Offline OP
NE Iowa
The wires at the right front hub became brittle and broke off on my '03 Ram, which set off the ABS codes obviously. I bought a new harness/sensor and replaced it last night.
I cleared the codes but the right front ABS sensor code is there immediately again after I just cleared them. Does this just need to reset itself after driving awhile, or did I do something wrong during installation?
Thanks in advance.
Re: Front ABS Sensor/Harness Replacement - '03 Ram [Re: Road_RunnerSteve] #1776361
03/10/15 12:42 PM
03/10/15 12:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks in advance.
it's my understanding that the sensor has to 'see' a few cycles to clear the code. I have to do this on my son's car so I've been reading up on it
Re: Front ABS Sensor/Harness Replacement - '03 Ram [Re: mikemee1331] #1776362
03/10/15 04:28 PM
03/10/15 04:28 PM
NE Iowa
NE Iowa
Well, I took the truck out on the highway over lunch and ran a few miles at speed. Shut it off and started it up when I got back to my office and the lights are off and all is right with the world.
Thanks for the input Mike.
