Wheel Well undercoating product #1776331
03/10/15 10:44 AM
03/10/15 10:44 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Anyone know of a wheel well undercoating in an aerosal can with wide spray application? I am looking to respray the front wheel wells in my Daytona. Since the car has an older restoration and shows "driving" conditions, I'm just looking to spruce things up a little in there. The restorer of the car back in '94 scraped most of the undercoating off from the front inner wheel well and I'm looking to reapply a coat...
Thanks in advance..
Troy
Houston Mopar Connection Club
Re: Wheel Well undercoating product [Re: hemi68charger] #1776332
03/10/15 10:52 AM
03/10/15 10:52 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I would suggest you re think that, invest in (link) A Cheap undercoating gun, and buy some of Resto Ricks stuff. It's an easy job to do right.
Re: Wheel Well undercoating product [Re: ScottSmith_Harms] #1776333
03/10/15 11:02 AM
03/10/15 11:02 AM
KY
65pacecar Offline
65pacecar  Offline
KY
I've had good luck with Wurth Undercoat in Aerosol, short of using a gun its the best I have found.
http://www.shopwurthusa.com/wurthstorefr...ting/p/88909071
Re: Wheel Well undercoating product [Re: 65pacecar] #1776334
03/10/15 12:26 PM
03/10/15 12:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I bought the 3M stuff ( and a shultz gun ) at my local auto parts store to do my old challenger,,and is what I'll use for the 68 Charger I am doing now.
YOU control the texture with air pressure and how quick you fan it across the area being coated.
Practice makes perfect
Re: Wheel Well undercoating product [Re: gtx6970] #1776335
03/10/15 08:34 PM
03/10/15 08:34 PM
OhiO
drgordi Offline
drgordi  Offline
OhiO
I used Ricks on my cuda and looks great. And blended very nice with the original.
Re: Wheel Well undercoating product [Re: ScottSmith_Harms] #1776336
03/11/15 01:14 AM
03/11/15 01:14 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I second that. easy to apply and looks OEM.
Re: Wheel Well undercoating product [Re: 67vertman] #1776337
03/11/15 09:26 AM
03/11/15 09:26 AM
Houston, Tx
Houston, Tx
With this comes the need for an air compressor....... I have a 80 gal., would that be big enough? It is one thing to buy the product and the spray gun applicator, but you have to have sufficient air.
Troy
Re: Wheel Well undercoating product [Re: hemi68charger] #1776338
03/11/15 03:09 PM
03/11/15 03:09 PM
sandbagger Offline
sandbagger  Offline
what about freshening up an area that's already undercoated?
"Hemmings Liftoff Hood Cover Bee"
"63 Savoy Max Wedge"
Re: Wheel Well undercoating product [Re: sandbagger] #1776339
03/11/15 03:54 PM
03/11/15 03:54 PM
Houston, Tx
Houston, Tx
For me, I'm just trying to freshen up and existing older restoration. Full-meal deal can happen when the day comes along to repaint the car..
Troy
Re: Wheel Well undercoating product [Re: hemi68charger] #1776340
03/11/15 04:15 PM
03/11/15 04:15 PM
Valley of the sun, AZ
2
2JcodeChargers Offline
Troy,
I second the idea of getting a gun and spraying Body Schutz. I think it is very correct in appearance to the "hard" factory undercoat.
It is not the size of your compressor that counts, it's the CFM it puts out, but in general terms, an 80 gallon compressor probably has a big enough motor to do what you want.
Chris
Re: Wheel Well undercoating product [Re: 2JcodeChargers] #1776341
03/13/15 10:54 PM
03/13/15 10:54 PM
Texas
carcrazyguy Offline
carcrazyguy  Offline
Texas
Just remember how hard it is to remove.... I have spent about 10 hours over the last three days and have not even got the rear wheel houses done.
Somewhere there is a person walking around Hamtramck laughing his butt off knowing he spent 5 minutes to spray on what would take 5 weeks to remove someday.
Re: Wheel Well undercoating product [Re: carcrazyguy] #1776342
03/13/15 10:58 PM
03/13/15 10:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You need one of these grasshopper! 3 hours and my Duster was squeaky clean, super hot water and pressure, ZERO scraping, all undercoating GONE!
Re: Wheel Well undercoating product [Re: ScottSmith_Harms] #1776343
03/13/15 11:07 PM
03/13/15 11:07 PM
Texas
carcrazyguy Offline
carcrazyguy  Offline
Texas
After media blasting.... What is left is soft and gooey. I am using a $20 oscillating multi tool and a standard scraper with some elbow grease.
Re: Wheel Well undercoating product [Re: carcrazyguy] #1776344
03/13/15 11:44 PM
03/13/15 11:44 PM
Texas
carcrazyguy Offline
carcrazyguy  Offline
Texas
Scott, guessing you did the pressure washing before you had the body stripped down to bare metal. Just curious if it would be worth paying a pressure wash company to come out and give it a shot? My car is in bare metal...and the thought of water on that...
Re: Wheel Well undercoating product [Re: carcrazyguy] #1776345
03/13/15 11:52 PM
03/13/15 11:52 PM
mr norms avenue
5571 Offline
5571  Offline
mr norms avenue
I just had my convertible done, and they used walnut shells to take that off. It took them about 10 minutes to do each rear wheel housing. Then they went and hit it with glass beads. Wow, it is now so nice (and done!)
When they went inside the rear quarters, they used the walnut shells again. It blew out that sound deadener. I wanted it out, as I did not trust that there was no rust lurking beneath it.
Walnut shells are wicked. They will leave some of the paint behind when taking the coating off.
Re: Wheel Well undercoating product [Re: carcrazyguy] #1776346
03/13/15 11:58 PM
03/13/15 11:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, however, you could mask off the rest of the car with plastic to keep it dry. Also, even if you don't get it wet, you'll need to prep it again (Metal etch, etc.) before priming of you'll have micro rust on your seemingly "clean" new bare metal which can lead to nasty paint problems later on..
Re: Wheel Well undercoating product [Re: 5571] #1776347
03/14/15 01:36 AM
03/14/15 01:36 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Bob, you have to fire up a new thread on how the blasting turned out on your car, I'd really like to see it......
Mo' Farts
Moderated by "tbagger".
