EFI WOT air fuel ratio for max power? #1775194
03/09/15 02:01 AM
03/09/15 02:01 AM
Nevada
dezduster Offline OP
Nevada
First would 11.8 be excessively rich for N/A engine at WOT?
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775195
03/09/15 02:11 AM
03/09/15 02:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... but you have to test to find the best ratio
Re: EFI WOT air fuel ratio for max power? [Re: MR_P_BODY] #1775196
03/09/15 02:24 AM
03/09/15 02:24 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
from everything I have read 12.5 -13 at WOT
That being said always tune for max MPH
has always helped me
keep an eye on your plugs
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: EFI WOT air fuel ratio for max power? [Re: MR_P_BODY] #1775197
03/09/15 02:27 AM
03/09/15 02:27 AM
Nevada
Nevada
Mr P thank you for that quick response.
Going to check on some chassis dyno time Monday. The nearest dyno is 135 miles away so cant just pop in. This is a 520 ci mopar would like to dial it in quickly anyone have a suggestion number wise?
Mr Pbody you are up late sir.
Re: EFI WOT air fuel ratio for max power? [Re: Stroker Scamp] #1775198
03/09/15 02:31 AM
03/09/15 02:31 AM
Nevada
Nevada
Well tuning for MPH in a 5200 pound 4x4 is well exciting. We can do this but looking at some dyno time maybe next weekend.
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775199
03/09/15 02:35 AM
03/09/15 02:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would look at about 12.8 ... and move from there...
this is on EFI .. what one... it should be trying
to drive it much leaner than that.. or are you making
a fuel map for it
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775200
03/09/15 03:55 AM
03/09/15 03:55 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Pump gas or Race fuel? Around here out "pump" gas is 10% Ethenol.
I'm adding a flex-fuel sensor to my FAST EFI, so it will compensate for the different percentages of alcohol in the gas.
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775201
03/09/15 07:49 AM
03/09/15 07:49 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
No actually, 11.8 is just off a tad. I would lean it out to 12.2-12.4 and call it a day...
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775202
03/09/15 11:32 AM
03/09/15 11:32 AM
NC
440Jim Offline
440Jim  Offline
NC
For what its worth, my 2-cents.
Assuming it is running on gasoline...
I would aim for about 12.2 at peak torque and 12.8 at peak horsepower. Drag race applications can often make a few more HP slightly leaner than that, but I like it a little rich (low 12's) lower in the rpm range.
These are just targets, and every application and engine may like slightly different.
Re: EFI WOT air fuel ratio for max power? [Re: 440Jim] #1775203
03/09/15 01:04 PM
03/09/15 01:04 PM
Nevada
Nevada
Thank you for everyone's input. Looking for dyno time now.
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775204
03/09/15 01:15 PM
03/09/15 01:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This is how most seem to tune........focusing on wfo and forgetting OR not knowing how to tune the idle and cruise circuits which usually are rich. Getting a clean n mean carb takes work but well worth it and fuel type and ign. timing help also. I run unleaded vp 101 and it likes richer mixtures as in low 12 s where the leaded liked more timing and richer mixtures at least for my car.......
Re: EFI WOT air fuel ratio for max power? [Re: Thumperdart] #1775205
03/09/15 01:32 PM
03/09/15 01:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its EFI.. and I'm thinking he is just trying to set
WOT and let the EFI control the rest
Re: EFI WOT air fuel ratio for max power? [Re: MR_P_BODY] #1775206
03/09/15 01:54 PM
03/09/15 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed on the efi but if he can map the tune, then it's that much sweeter.....
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775207
03/09/15 04:09 PM
03/09/15 04:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
How much differences are there between the chassis dyno in Reno and where your pull off is going to be ? If similar, within 500 Ft of each other, tune it for best power on the dyno, if it is more than 500 ft difference you may need to change the jet(all of them ) size one number using Holley jets for best performance, leaner if higher, richer if lower
Re: EFI WOT air fuel ratio for max power? [Re: Cab_Burge] #1775208
03/09/15 04:38 PM
03/09/15 04:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
CAB.... ITS EFI
Re: EFI WOT air fuel ratio for max power? [Re: MR_P_BODY] #1775209
03/09/15 06:11 PM
03/09/15 06:11 PM
Nevada
Nevada
Elevation here is 4000 Reno 4400.
So the 20th is the dyno date.
It's not my engine or truck and I'm excited about this.
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775210
03/09/15 06:50 PM
03/09/15 06:50 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
my 2 cents is 13.7 to 14 driving on the flat cruise and 13.0 to 13.3 on the floor. check your plugs in both conditions.
Re: EFI WOT air fuel ratio for max power? [Re: dezduster] #1775211
03/09/15 07:13 PM
03/09/15 07:13 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Not exactly an answer, but
To find the best main jet using MPH:
1. if not a full 1/4 mile, use the fastest continuous pull in high gear
2. start with main jets too rich
3. reduce the mains 1 size at a time
4. each size drop should increase the MPH
5. when it doesn't, go back 1 step to the previous jets
Summary: you want the leanest jet that doesn't drop MPH (the point where +1 rich doesn't help, -1 lean slows down). Depending on your gearing, air temp, water temp, scoop shape, exhaust, and about 10 other factors it could be anywhere between 11.8 - 13.5.
Boffin Emeritus
Re: EFI WOT air fuel ratio for max power? [Re: polyspheric] #1775212
03/09/15 09:45 PM
03/09/15 09:45 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You have to test it at a few different extremes. There is no set number until KNOW what it like. I ran my EZ Efi at 12.2 WOT for 2 months and right before I pulled the motor because it was sold, I tried 11.8 and it came alive. Nobody I researched ever went that rich with that system, my engine without a doubt liked it.
Mopar to the bone!!!
Re: EFI WOT air fuel ratio for max power? [Re: 72Swinger] #1775213
03/09/15 10:42 PM
03/09/15 10:42 PM
NC
440Jim Offline
440Jim  Offline
NC
72Swinger,
That goes to show that some engine combos are more fuel efficient that others (BMSF). Some need more fuel for the same power, some do better at less.
