Fire jacket
#177508
12/28/08 09:36 PM
12/28/08 09:36 PM
Posts: 82 florida
hemifw
florida
Who has the best fire jacket? I hope to run 10.50s Not sure what I will need clothing wise for nhra.
71 Demon
Re: Fire jacket
[Re: hemifw]
#177509
12/28/08 11:48 PM
12/28/08 11:48 PM
Posts: 43,209 Bend,OR USA
Cab_Burge
The jacket needed is dependent on the car and how it is finished inside the drivers compartment, I may be wrong but you should really EM either your local NHRA division tech. director or NHRA tech. department. Give them the specs on the car, which type or class you want to run in, stock intereior or not, type of fuel your going to run and so on. Make sure and ask for a written reply with SFI spec # needed for the jacket and a list of the other mandatory parts you will need for you and the car
