Gen 3 max effort hp?
#1774026
03/07/15 09:46 AM
03/07/15 09:46 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
OK, this is a fun post for those guys stuck inside, and insomniacs like me. If you were to tackle a stroker Gen 3 motor for high hp brackets, what do you think it would make for power? Lets say we go with 426 cubes, 14.5 + compression, best available valvetrain, custom tunnelram, dual Dominators or Termintors with alky, (your choice),vacuum pump, the usual stuff for close to the best that can be built. I am assuming a large bore aluminum Mopar block, or at least a 4.090 bore. Opinions?
Re: Gen 3 max effort hp?
[Re: gregsdart]
#1774027
03/07/15 03:28 PM
03/07/15 03:28 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Aluminum block large bore 3.79 stroke Thitek heads. Spine the thing to 9000 rpm and I believe 1000 hp will be obtainable. Dave Barton has gone 148 in his 3300 lbs challenger which is 888.88 hp Matt
[Re: gregsdart]
#1774028
03/07/15 03:52 PM
03/07/15 03:52 PM
Posts: 345 Nebraska
451Cuda
Nebraska
And which pieces will live at that hp level? I'm contemplating the switch from BB to gen 3 and checking CL for core engines. Stock block ok? Which core engines to avoid, if any?
[Re: 451Cuda]
#1774029
03/07/15 05:51 PM
03/07/15 05:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Stock blocks are fine N/A aspirated. I know Bartons tach hit 88-8900 in one of his in car videos. Im guessing he has Jesel keyway lifters and rockers. That is probably $5000 alone. But if the engine peaks in the 7000 rpm range, stock rockers and lifters have proven to live just fine.
Mopar to the bone!!!
[Re: 72Swinger]
#1774030
03/08/15 12:17 PM
03/08/15 12:17 PM
MattW
Ontario Canada
I've heard differently about the rockers. HS is what I've heard he runs Be nice to know what he runs. Matt
[Re: fbs63]
#1774032
03/08/15 03:42 PM
03/08/15 03:42 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Digby's Dart or the Goss Challenger are just two examples of late model Hemi getting it done. This site will never be a Gen 3 tech hot bed. You need to move to other sites with a younger group of guys. This place Is stuck in the past. Challengertalk.com is one.
[Re: FastmOp]
#1774035
03/08/15 05:43 PM
03/08/15 05:43 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Digby give up on the predator headed engine??
[Re: GTS340]
#1774036
03/08/15 06:17 PM
03/08/15 06:17 PM
FastmOp
Hot Rod Ridge
Nope. I forgot he's predator heads. Sorry! The Goss Challenger might not be either. I'm getting old
[Re: FastmOp]
#1774038
03/08/15 10:43 PM
03/08/15 10:43 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Goss Challenger is G3 BES power
