CD stuck in deck 2003 RAM #1773750
03/06/15 09:30 PM
03/06/15 09:30 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Today while listening to a CD in the stock system in my 20013 RAM 1500 the unit went dead mid song. I tried to eject the CD but it just wont come out. Any ideas on why it just go bad like that and how to get the CD out of the deck?
Thank you
Stu
Re: CD stuck in deck 2003 RAM [Re: MidPenMopar] #1773751
03/06/15 10:16 PM
03/06/15 10:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you check fuses etc? Maybe try pulling the radio fuse and see if resets.
Re: CD stuck in deck 2003 RAM [Re: stumpy] #1773752
03/06/15 10:29 PM
03/06/15 10:29 PM
The deck is working, just wont eject. You can hear it trying to push it out but it wont go. I dont think its a power issue.
Re: CD stuck in deck 2003 RAM [Re: MidPenMopar] #1773753
03/06/15 11:59 PM
03/06/15 11:59 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
sort of a common problem. you can slap the dash, above the radio, while trying to eject it. otherwise, just wait for it. i have one that steals discs from time to time. sometimes a slap gets it back, sometimes it decides to give it back, days after.
Re: CD stuck in deck 2003 RAM [Re: Golden-Arm] #1773754
03/07/15 12:00 PM
03/07/15 12:00 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I've got one that sticks sometimes too, can't remember which vehicle. I stick another CD in the slot and bump the edge of the first one that's stuck. Sometimes bump it more than once. It has always then come out. Be VERY cautious about slapping the dash on a Ram truck, they are well known to shatter when the plastic gets brittle. Particularly bad on Gen II rams, '94-01 (+'02 HD). Not so sure if this applies to newer Rams.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: CD stuck in deck 2003 RAM [Re: GO_Fish] #1773755
03/07/15 12:11 PM
03/07/15 12:11 PM
Thanks guys i will try those ideas today and see what happens.
Re: CD stuck in deck 2003 RAM [Re: MidPenMopar] #1773756
03/08/15 09:33 PM
03/08/15 09:33 PM
I tired all your ideas but to avail. I disconnected the fuse, I beat the crap out of the dash, I used another CD to help get the first CD out, but now that one is stuck.....
I made a Valiant effort anyway!
Re: CD stuck in deck 2003 RAM [Re: MidPenMopar] #1773757
03/08/15 11:22 PM
03/08/15 11:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How about a pair of tweezers or hemostats to grab it with?
Re: CD stuck in deck 2003 RAM [Re: stumpy] #1773758
03/08/15 11:46 PM
03/08/15 11:46 PM
Just tried that and got it out.
Well so much for the CD player...
Re: CD stuck in deck 2003 RAM [Re: MidPenMopar] #1773759
03/09/15 12:25 AM
03/09/15 12:25 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the player wasn't hurt digging the cd out try blasting it with a shot of canned pressurized air. The stuff you use on computers. Then get an old CD and try it.
Re: CD stuck in deck 2003 RAM [Re: stumpy] #1773760
03/09/15 12:27 AM
03/09/15 12:27 AM
Ok, i am up for anything at this point.
Re: CD stuck in deck 2003 RAM [Re: MidPenMopar] #1773761
03/10/15 12:43 PM
03/10/15 12:43 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I don`t know if your cd player is the same but I had one that the plastic gear inside was stripped.
Re: CD stuck in deck 2003 RAM [Re: mopars4ever] #1773762
03/14/15 04:30 PM
03/14/15 04:30 PM
New problem, now the sound stopped working. The unit seems to work fine but no sounds from the speakers. It was come on for a few minutes then go off for a few hours. You can see all the functions working just no sound coming out. I tried the fust thing again, but no luck.
Does this mean the end of the head unit?
If so should i ask around on here for a stock unit someone took out of there truck?
Re: CD stuck in deck 2003 RAM [Re: MidPenMopar] #1773763
03/14/15 04:38 PM
03/14/15 04:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
They are pretty cheap on ebay.
Re: CD stuck in deck 2003 RAM [Re: stumpy] #1773764
03/14/15 05:26 PM
03/14/15 05:26 PM
Guitar Jones Offline
There are places that will repair them, not sure it's worth it or not, shop around.
Re: CD stuck in deck 2003 RAM [Re: stumpy] #1773765
03/14/15 06:09 PM
03/14/15 06:09 PM
I see one that is rebuilt and with an added I-Pod port for $155 with free shipping.
