Retrofit roller lifters? (Oops...) #177367
12/28/08 08:18 PM
12/28/08 08:18 PM
SW FL
dodgedartgt Offline OP
SW FL
When I originally posted, I typed roller rockers... What I meant and would like to learn about is roller lifters, SO...
Can someone tell me about retro fitting roller lifters into a '76 vintage LA block? Brands, prices, modifications necessary, anything else you can think of.
TIA, Mike
Re: Retrofit roller rockers? [Re: dodgedartgt] #177368
12/29/08 12:18 PM
12/29/08 12:18 PM
SW FL
SW FL
BTTT,
Thanx, Mike
Re: Retrofit roller rockers? [Re: dodgedartgt] #177369
12/29/08 12:41 PM
12/29/08 12:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
WHy do you want roller rockers??? They will give you no HP advantage over a set of dictile iron. The only advantage that they will have over the stamped OEM rockers is truer ratio. Here by Dulcich.
Re: Retrofit roller lifters? [Re: MoparforLife] #177370
12/29/08 03:33 PM
12/29/08 03:33 PM
SW FL
SW FL
Thanks MoparforLife,
I made a typo when I posted this originally... What I meant was retrofit roller lifters... sorry and thanx.
Mike
Re: Retrofit roller rockers? [Re: MoparforLife] #177371
12/29/08 04:45 PM
12/29/08 04:45 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Some of us like reving our engines over 5K, and besides, lightening the valvetrain is ALWAYS a good idea.
Re: Retrofit roller rockers? [Re: BergmanAutoCraft] #177372
12/29/08 07:10 PM
12/29/08 07:10 PM
Upper Midwest
Upper Midwest
Rollers ain't the answer for that. Better places to spend the money than that if that is the reason you are looking at. I don't like picking little needles out of the engine either.
Roller cam is a completely different story.
Re: Retrofit roller rockers? [Re: MoparforLife] #177373
12/29/08 08:17 PM
12/29/08 08:17 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
Not roller cam. You're thinking about roller cam bearings.
To retrofit for roller lifters you need to bush the lifter bores. The sleeves will still end up being .904. You will need to find a shop with a special cam tunnel fixture for LA. They need to use this fixture to bush the bores, it needs to be LA specific.
The closest shop I found was 100 + miles away. I was debating sending the block to Hughes before I found them.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: Retrofit roller rockers? [Re: go-fish] #177374
12/29/08 08:46 PM
12/29/08 08:46 PM
Upper Midwest
Upper Midwest
Wrong answer! Been in this game long enough to know that a hydraulic roller cam is the terminology used to describe a camshaft ground to use a hydraulic roller lifters.
Not referring to a camshaft using roller cam bearings
Re: Retrofit roller rockers? [Re: go-fish] #177375
12/29/08 08:46 PM
12/29/08 08:46 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I am running the Crane Hydraulic Retrofit Roller Lifters and the block was not bushed. I did have to have a custom smaller base roller cam made up so the lifter oil grooves would not be exposed at max lift.
Re: Retrofit roller rockers? [Re: 69Cuda340S] #177376
12/29/08 08:49 PM
12/29/08 08:49 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I did have to grind the block on the upper lifer valley to get them to go in. Very minor grinding though.
Re: Retrofit roller rockers? [Re: 69Cuda340S] #177377
12/29/08 09:53 PM
12/29/08 09:53 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
STOCK 340 BLOCK
Chris from New Jersey
Re: Retrofit roller rockers? [Re: fig426] #177378
12/30/08 02:04 AM
12/30/08 02:04 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
A bump as I am also interested in this. BUMP
Re: Retrofit roller rockers? [Re: dezduster] #177379
12/30/08 12:34 PM
12/30/08 12:34 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Is this a problem on all early pre roller blocks?
Re: Retrofit roller lifters? [Re: mopars4ever] #177380
12/30/08 05:45 PM
12/30/08 05:45 PM
SW FL
SW FL
Waht year did the 318/5.2 & 360/5.9 become roller lifter blocks?
Also... BUMP!
Thanks, Mike
Re: Retrofit roller rockers? [Re: mopars4ever] #177381
12/30/08 06:09 PM
12/30/08 06:09 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Depends on the block and how high a lift the cam has. On my '71 340 block the top of the lifer bores had a chamfer machined into them and that caused the oil groove to be exposed. But the machining was not consistent. Some sealed really well and others did not. Brian at IMM (user ou812) had a cam ground for me that solved the problem. Was about the same price as an off the shelf retrofit roller cam.
Re: Retrofit roller lifters? [Re: dodgedartgt] #177382
12/31/08 12:16 AM
12/31/08 12:16 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Also... BUMP!
Thanks, Mike
They started showing up ready for a roller in late '84 even though many still used flat tappets until '87-88.
Re: Retrofit roller lifters? [Re: MoparJoe] #177383
01/01/09 02:30 AM
01/01/09 02:30 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
For the cost and trouble of converting to a roller cam, you would be nuts if you didn't just find a later stock roller cam block.
Re: Retrofit roller lifters? [Re: DaytonaTurbo] #177384
01/01/09 01:03 PM
01/01/09 01:03 PM
ERIE PA home of the RENCH MOB
mike_vango Offline
mike_vango  Offline
i agree!!
Re: Retrofit roller lifters? [Re: mike_vango] #177385
01/01/09 05:24 PM
01/01/09 05:24 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
i agree!!
A lot cheaper that way too.
Re: Retrofit roller lifters? [Re: 69Cuda340S] #177386
01/02/09 08:49 PM
01/02/09 08:49 PM
SW FL
SW FL
Thanks for every ones input... Anyone else have any thoughts?
Mike Bynum
