Hydroboost on "stock-ish" brakes? #1771948
03/05/15 05:04 AM
03/05/15 05:04 AM
Sorrento, BC, Canada
4speeds4me Offline OP
Is it worth it with a traditional disc/drum brake setup? And if it is, what booster makes a budget friendly option for a B-body?
Thanks!
2 Demons...no, not my kids!
Re: Hydroboost on "stock-ish" brakes? [Re: 4speeds4me] #1771949
03/05/15 10:40 AM
03/05/15 10:40 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Hydros put out a lot of pressure. I use them a lot but not with drums in the back. Worst case you run a valve to drop the pressure to the rear and/or smaller wheel cylinders. I swear by these.
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771950
03/05/15 11:14 PM
03/05/15 11:14 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
There are countless trucks and vans with disk/drum hydroboost systems. It's just a booster, no different than a vacuum system.
Re: Hydroboost on "stock-ish" brakes? [Re: Skeptic] #1771951
03/05/15 11:52 PM
03/05/15 11:52 PM
So then, what is a cost effective unit from on OE application that adapts easily?
Re: Hydroboost on "stock-ish" brakes? [Re: 4speeds4me] #1771952
03/05/15 11:56 PM
03/05/15 11:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I suggest you drive a hydroboost vehicle to see if you like the feel, especially the donor. I do not.
Don't be the exception.
Re: Hydroboost on "stock-ish" brakes? [Re: 4speeds4me] #1771953
03/06/15 05:10 AM
03/06/15 05:10 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
GM trucks and vans ran these things and GM diesel cars. I'll second the drive one first suggestion. Personally, I hate the pedal feel of a hydroboost setup
Re: Hydroboost on "stock-ish" brakes? [Re: ntstlgl1970] #1771954
03/06/15 09:47 AM
03/06/15 09:47 AM
Long Island, NY USA
Long Island, NY USA
For the people who say they don't like the hydroboost, what experience are you basing your opinion on? I run gen 3 viper calipers with 14.25 rotors and the cobra rear calipers with 11.75 rear rotors with Carbo tech pads, srf fluid and braided lines. Down the straight at 130 and braking with ease to turn one at Lime Rock. I watch others struggle to slow down. I couldn't be happier with these units. However, I'm using new Hydratech units in all my applications.
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771955
03/06/15 10:49 AM
03/06/15 10:49 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What do you think we are basing it on? Stock applications and based on driving stock hydroboosted GM and Fords I do not like the feel. Does it stop? Yes. Do you have good pedal feel and feedback, no.
So I do not like it. Dunno about Hydratech, but I am not spending the money to find out.
Re: Hydroboost on "stock-ish" brakes? [Re: Supercuda] #1771956
03/06/15 12:04 PM
03/06/15 12:04 PM
Long Island, NY USA
Long Island, NY USA
Relax. There are many different scenarios to consider before you condemn something, which is often done on this board.
Poor pedal "feel" is usually a result of a single piston caliper giving an on/off type of feel. As you get into more advanced systems with multiple pistons, the feel becomes excellent. The systems we use are new and are time tested combinations.
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771957
03/06/15 12:46 PM
03/06/15 12:46 PM
All fine and good, but considering my original question, this is a fair assessment, and was one of my concerns, frankly. I have 2 diesel pickups. One has a "traditional" vacuum booster, and the other has a hydroboost setup. I've never really been comfortable with the feel of the hydroboost truck.
That said, I agree that this opinion is subjective. However, the vehicle in question will likely be OE calipers up front and and 11x2.5 drums out back...
Re: Hydroboost on "stock-ish" brakes? [Re: 4speeds4me] #1771958
03/06/15 12:56 PM
03/06/15 12:56 PM
Long Island, NY USA
Long Island, NY USA
Given that scenario, you would have more of an on/off feel. If you don't have the vacuum to run the brakes properly, I'd investigate other means, like the electric assist unit. I haven't used them, but I know there are alternatives out there. Personally, I do not care for manual brakes.
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771959
03/06/15 05:31 PM
03/06/15 05:31 PM
Essentially a stock 2013 5.7 with full length headers and mild tuning...vacuum shouldn't be an issue...
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771960
03/06/15 06:14 PM
03/06/15 06:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I don't have a minimum of a grand to spend on hydroboost to find out. Your preferred setup prices out kinda up there and then I still have to add P/S pump and such. I have a manual steering and manual brake car and I do not have a problem with that. As for the feel getting better with more pistons, how much more is that? $2-3000 to find out?
Re: Hydroboost on "stock-ish" brakes? [Re: Supercuda] #1771961
03/06/15 07:49 PM
03/06/15 07:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I have to say that the hot rod had the best brake feel I've experienced.
It used all four corners of a 2005 Mercedes S55 brake system and a 1-1/8" D100 manual master cylinder.
The pedal felt a little firmer than most power assisted systems but softer than the old factory manual brake cars/trucks I've had.
When the pedal moved, the car slowed straight and true. Modulation was easy and drama free.
- Stu Harmon
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771962
03/06/15 09:04 PM
03/06/15 09:04 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I'm basing my opinion on the GM and Ford trucks and GM cars that had hydroboost that I have worked on. They all worked fine, I just don't like the over assisted pedal feel.
Re: Hydroboost on "stock-ish" brakes? [Re: Supercuda] #1771963
03/06/15 09:44 PM
03/06/15 09:44 PM
Long Island, NY USA
Long Island, NY USA
Real brakes cost real money, its just the way it is. The difference between stock disc/drum and modern brake systems is so dramatic they feel to me they have no brakes compared to my Dart. For instance, I drive a Magnum RT. Good size brakes for a regular car. Compared to the Dart they flat out suck.
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771964
03/06/15 10:53 PM
03/06/15 10:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not pissing away several grand to find out if I like the way your setup feels.
Guess he more it costs the realer it is.
Re: Hydroboost on "stock-ish" brakes? [Re: BergmanAutoCraft] #1771965
03/06/15 10:57 PM
03/06/15 10:57 PM
IN
ahy Offline
ahy  Offline
IN
Stock brakes generally have adequate boost with the vacuum booster. I would expect limited gain most of the time with hydroboost. Some aftermarket setups (like mine) need more boost due to smaller front piston area. Also may be a benefit with significantly larger than stock tire diameter which can reduce brake force.
Re: Hydroboost on "stock-ish" brakes? [Re: ahy] #1771966
03/07/15 12:35 AM
03/07/15 12:35 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'm looking at Tom's Valiant and unless I missed he's running stock A body discs up front and Mustang rear discs out back and killing lots of "modern" iron.
I guess if I ever plan to hit the Silver State Challenge or try to beat my personal banzai run from San Diego to Tucson's time (4.5 hours to cover 400 miles) I don't need much bigger than I have.
Re: Hydroboost on "stock-ish" brakes? [Re: Supercuda] #1771967
03/07/15 02:09 AM
03/07/15 02:09 AM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
It’s always amazed me how we attack each other on Moparts when we don’t agree. I understand Peter to say that if you’re going to road race, you need a brake system to support that specific type of driving. I get that and I’m building as much braking capacity into my Duster that I can afford. I do want to be able to “haul down” from 120Mph+ as quickly as possible.
An autocross cannot be compared to a road course; they are two different animals. Does everyone large need 4-wheel disc brakes and a hydro-boost? No they don’t, pick what works for your style of driving.
1971 6.1 Gen III Hemi Duster
