Stock 426 Hemi Total Timing question. #177112
12/28/08 04:43 PM
12/28/08 04:43 PM
Anonymous OP
Anonymous OP
what do you guys run for total timing for a 1969 stock street hemi roasdrunner?
would 28-30 degrees be acceptable? thanks
Re: Stock 426 Hemi Total Timing question. #177113
12/28/08 04:47 PM
12/28/08 04:47 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
dont worry about detonation its got 170 cc head, put it @ 36 degrees total @ 2500 rpm,your giving up power with low timing, sometimes 38-40 works but eats way more feul
MOPAR OR NO CAR
Re: Stock 426 Hemi Total Timing question. [Re: hemigod426] #177114
12/28/08 04:54 PM
12/28/08 04:54 PM
Anonymous OP
Anonymous OP
i am having a rough time starting with 36 total timing.
darn red top batteries stink and wont crank it over at 36 degrees.
looks like im around 30-32 degrees at 2000 rpm.
Re: Stock 426 Hemi Total Timing question. #177115
12/28/08 04:59 PM
12/28/08 04:59 PM
hemigod426 Offline
hemigod426  Offline
dail up #1, your tdc on balancer is off, dont go by stock mark, put on timing tape on stock balancer
MOPAR OR NO CAR
Re: Stock 426 Hemi Total Timing question. #177116
12/29/08 12:45 AM
12/29/08 12:45 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I found 32-35 works best.
Re: Stock 426 Hemi Total Timing question. [Re: torkrules] #177117
12/29/08 10:50 PM
12/29/08 10:50 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
34 on my Hemi
Re: Stock 426 Hemi Total Timing question. [Re: Michael] #177118
12/29/08 10:56 PM
12/29/08 10:56 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
you need to recurve the dist if its backing up on you due to overadvanced initial to get the 35 total my 66 hemi car totally stock liked 34-37 depending on how hot it was outside! IIRC i had 12 initial plugged vac advance good luck dan
Re: Stock 426 Hemi Total Timing question. [Re: ph23vo] #177119
12/29/08 11:38 PM
12/29/08 11:38 PM
Anonymous OP
Anonymous OP
just set it to 33 total, seems to like it.its just a show poodle so its not like im going to spin the heck out of it. now it seems to start nicely.
Re: Stock 426 Hemi Total Timing question. #177120
12/29/08 11:47 PM
12/29/08 11:47 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i just think a HEMI should run like its supposed to show poodle or not... my original cam/compression std bore 19k mile 66 hemi 4 speed car ran low 14,s when i first got it running took a year to dial it in to 13:30,s 105mph ... mine was the fastest real stock hemi car in the area as most couldnt get in the 15,s even! good luck make it run! dan
