GM 1-wire bracketry for '68 440 Charger with AC??
#1771065
03/04/15 01:02 PM
03/04/15 01:02 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
I've got a '68 Charger here....has a 440, factory AC and PS with factory bracketry...Does anyone make a bracket to install a GM 1-wire alternator?? or is there a really good/reliable alternator with built in regulator that bolts right in?? Thanks!
If you can't handle the truth, you're living a lie.......
Re: GM 1-wire bracketry for '68 440 Charger with AC??
[Re: Big Squeeze]
#1771066
03/06/15 12:10 AM
03/06/15 12:10 AM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
Powermaster has new high amp 1 wire alternators bolt on replacement for Mopars now.
Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: Big Squeeze]
#1771069
03/11/15 03:24 PM
03/11/15 03:24 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Powermaster would be your easiest bet....before PM came along I didnt have a choice (okay, I did) but I installed a 10si Delco 100a on my 440, no A/C though. Custom bracket out of stainless and then used the upper alternator bracket from a small block as the lower bracket for the 10si. Works great
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
