2010 Power Wagon rear axle trouble #1770974
03/04/15 03:05 AM
03/04/15 03:05 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
My 2010 Power Wagon finally started to get a bad vibration, only has 42000 miles. Dealer found rear driveshaft U-joint bad, still had vibration, found front axle u-joint bad, still had vibration. They put different wheels and tires on, change to another drive shaft. Still had vibration. They finally listened after I told them, it was a u-joint bad or one of the axles has a bad bearing or ring and pinion going bad. Now the rear axle is going to be rebuilt, so far the bearings are bad. Some dealers will not listen. Sure am glad it still under warranty.
Re: 2010 Power Wagon rear axle trouble [Re: 68dodge] #1770975
03/05/15 09:31 PM
03/05/15 09:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
When you claim a vibration to me that associates u-joints, drive shafts, tire balance. A bad bearing should be a hum or drone noise and may change on acceleration or de-acceleration. Sounds to me like they corrected some issues and the final issue is a noise.
Re: 2010 Power Wagon rear axle trouble [Re: 68dodge] #1770976
03/05/15 09:58 PM
03/05/15 09:58 PM
Greenville, PA
redraptor Online tonguue
redraptor  Online Tonguue
Greenville, PA
Did you buy this truck new? I can't see these issues with a truck of that mileage unless it was abused. Not accusing and yes there are lemons.
Re: 2010 Power Wagon rear axle trouble [Re: redraptor] #1770977
03/06/15 06:54 PM
03/06/15 06:54 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Update, rear axle is rebuilt, dealer replace carrier bearing and axle bearings, still have problems, now they think it is in the transfer case. I bought this truck new. The truck is not abused. Truck see's more towing time then anything, I haul 6 ton a coal a year with it, 1 ton at a time.
Re: 2010 Power Wagon rear axle trouble [Re: 68dodge] #1770978
03/06/15 09:05 PM
03/06/15 09:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Did they replace the rear pinion bearings???
