Front fuel cell mounting #1770242
03/03/15 04:51 PM
03/03/15 04:51 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I Have a toilet bowl set up for my Barracuda. Any one have pictures of a fuel cell mounted in the front? Is there one that works better than others? Thinking i will need a 4 gallon. Thanks
Re: Front fuel cell mounting [Re: bobs69] #1770243
03/03/15 10:01 PM
03/03/15 10:01 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
2 gal. in a abody just did it a few weeks ago ...also running rons toilet..hope that helps out some
Re: Front fuel cell mounting [Re: earthmover] #1770244
03/03/15 10:02 PM
03/03/15 10:02 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Re: Front fuel cell mounting [Re: bobs69] #1770245
03/04/15 02:26 AM
03/04/15 02:26 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Make sure cell fuel is above the pump and the top of the cell is not above the nozzles.
Joe
Without Data, you’re just another guy with an opinion.
Re: Front fuel cell mounting [Re: bobs69] #1770246
03/05/15 10:23 AM
03/05/15 10:23 AM
NC
440Jim Offline
440Jim  Offline
NC
What does the front of your car look like? (pic) Stock radiator support? Inner fenderwells? It can be a pain in a mostly stock A-body, but it can be done with some work. I have a 4 gallon fuel cell and I would not want only 2 gallons.
Re: Front fuel cell mounting [Re: bobs69] #1770247
03/05/15 11:31 AM
03/05/15 11:31 AM
gregsdart Offline
gregsdart  Offline
When you mount it, be sure you can build it so the protective bar is above the top fitting on the tank. I got called on that at my last cage cert, luckily not at the track. Minimum 2 gal gas, 4 for alky and you need the pump pickup in the back to ensure it won't uncover the pickup on launch if it isn't real full. AMHIK.
Re: Front fuel cell mounting [Re: gregsdart] #1770248
03/05/15 11:42 AM
03/05/15 11:42 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
This is my custom built 3.75 gal. Mounted front Right.
Re: Front fuel cell mounting [Re: cl440] #1770249
03/05/15 11:43 AM
03/05/15 11:43 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Fuel pump mounted front Left down low.
Re: Front fuel cell mounting [Re: bobs69] #1770250
03/05/15 12:32 PM
03/05/15 12:32 PM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
Re: Front fuel cell mounting [Re: Fast Yeti] #1770251
03/05/15 05:38 PM
03/05/15 05:38 PM
This is my 1970 Cuda that had this custom made alumimun cell in it when I got the car several years ago. It holds around 6 gallons, the electric fuel pump is mounted between the motor and the cell, electric the pump you see in this picture is for the cooling system, I'll post another one after this to show it with the filters and plumbing. I run this car on E85 due to the very small cooling system
Re: Front fuel cell mounting and electric pump [Re: Cab_Burge] #1770252
03/05/15 05:41 PM
03/05/15 05:41 PM
This pictures shows the electric fuel pump and dual fuel flters on my car, 100 micron between the tank and the pump and a 10 micron between the pump and fuel regulator IHTH s
