Re: Front fuel cell mounting
[Re: earthmover]
#1770244
03/03/15 10:02 PM
03/03/15 10:02 PM
Posts: 2,449 nc
earthmover
nc
[Re: bobs69]
#1770245
03/04/15 02:26 AM
03/04/15 02:26 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Make sure cell fuel is above the pump and the top of the cell is not above the nozzles.
Joe
Without Data, you’re just another guy with an opinion.
[Re: bobs69]
#1770246
03/05/15 10:23 AM
03/05/15 10:23 AM
Posts: 16,928 NC
440Jim
NC
I Have a toilet bowl set up for my Barracuda. Any one have pictures of a fuel cell mounted in the front? Is there one that works better than others? Thinking i will need a 4 gallon. Thanks
What does the front of your car look like? (pic) Stock radiator support? Inner fenderwells? It can be a pain in a mostly stock A-body, but it can be done with some work. I have a 4 gallon fuel cell and I would not want only 2 gallons.
[Re: bobs69]
#1770247
03/05/15 11:31 AM
03/05/15 11:31 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
When you mount it, be sure you can build it so the protective bar is above the top fitting on the tank. I got called on that at my last cage cert, luckily not at the track. Minimum 2 gal gas, 4 for alky and you need the pump pickup in the back to ensure it won't uncover the pickup on launch if it isn't real full. AMHIK.
[Re: bobs69]
#1770250
03/05/15 12:32 PM
03/05/15 12:32 PM
Posts: 404 Dana Point, CA
Fast Yeti
Dana Point, CA
[Re: Fast Yeti]
#1770251
03/05/15 05:38 PM
03/05/15 05:38 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
This is my 1970 Cuda that had this custom made alumimun cell in it when I got the car several years ago. It holds around 6 gallons, the electric fuel pump is mounted between the motor and the cell, electric the pump you see in this picture is for the cooling system, I'll post another one after this to show it with the filters and plumbing. I run this car on E85 due to the very small cooling system
Re: Front fuel cell mounting and electric pump
[Re: Cab_Burge]
#1770252
03/05/15 05:41 PM
03/05/15 05:41 PM
Cab_Burge
This pictures shows the electric fuel pump and dual fuel flters on my car, 100 micron between the tank and the pump and a 10 micron between the pump and fuel regulator IHTH s
