Which manual valve body to look for? #1770195
03/03/15 03:52 PM
03/03/15 03:52 PM
NH
torredcuda Offline OP
NH
Stock 727 behind mild 340 porbably only running 12`s for now, which manual valve body should I look for, money is tight so trying to find used but will buy new if recommended? ANy other easy mods to make?
Re: Which manual valve body to look for? [Re: torredcuda] #1770196
03/03/15 07:23 PM
03/03/15 07:23 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
1. Forward pattern or reverse? (I.e., are you trying to keep using an original Slap-Stik shifter, or does it have something else that can work either way?)
2. Low-band apply (probably, based on your description) or not?
Re: Which manual valve body to look for? [Re: BradH] #1770197
03/03/15 08:33 PM
03/03/15 08:33 PM
NH
NH
aftermarket shifter B & M pro stick so either pattern will work and I would think I want LBA but not sure?
Re: Which manual valve body to look for? [Re: torredcuda] #1770198
03/03/15 09:56 PM
03/03/15 09:56 PM
BradH Offline
BradH  Offline
Street driven, or track only?
Re: Which manual valve body to look for? [Re: BradH] #1770199
03/03/15 10:39 PM
03/03/15 10:39 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
How about making a full list for future reference?
1. Street only, forward pattern
2. Street only, reverse pattern
3. Street/Strip, forward pattern
4. Street/Strip, reverse pattern
5. Strip only, forward pattern, LBA (?)
6. Strip only, reverse pattern, LBA
Should there be 727 and 904 breakdown?
Does HP change VB application?
Re: Which manual valve body to look for? [Re: RodStRace] #1770200
03/03/15 11:40 PM
03/03/15 11:40 PM
NH
NH
track only.
Re: Which manual valve body to look for? [Re: torredcuda] #1770201
03/03/15 11:52 PM
03/03/15 11:52 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
track only.
#6
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Which manual valve body to look for? [Re: torredcuda] #1770202
03/04/15 12:30 AM
03/04/15 12:30 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
You could make your own Rev manual using a good core VB and purchasing an ATI separator plate. Using a mill or drill press with an end mill, you can modify the channel walls and reassemble the kickdown valve and throttle pressure valve in the correct orientation.
www.atiracing.com
P/N 723210, $49.00
Otherwise, the Griner 22G05B is the superior RMVB available. Can also contact John Cope and coperacingtrans.com
727specialist is a dealer for Griner
Re: Which manual valve body to look for? [Re: torredcuda] #1770203
03/04/15 11:55 AM
03/04/15 11:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW I drive to the track and race. I use a Turbo Action RMVB. No problems in 4 years.
Coming soon!!!!
Re: Which manual valve body to look for? [Re: torredcuda] #1770204
03/04/15 12:32 PM
03/04/15 12:32 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
call john cope. get one of his. CRT hands down.
Re: Which manual valve body to look for? [Re: mopar dave] #1770205
03/04/15 02:13 PM
03/04/15 02:13 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
+1. John da man!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Which manual valve body to look for? [Re: DusterDave] #1770206
03/04/15 02:35 PM
03/04/15 02:35 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been using Turbo Action RMVB's on the street since 1997 with no problems. But you need to be aware of what you have and drive it correct. Ron
Re: Which manual valve body to look for? [Re: RodStRace] #1770207
03/04/15 03:35 PM
03/04/15 03:35 PM
BradH Offline
BradH  Offline
IMO, options #1 & 2 make no sense; 99% of the people use a MVB in either street/strip cars or race cars.
Everybody else can leave it in "D".
Re: Which manual valve body to look for? [Re: BradH] #1770208
03/04/15 04:00 PM
03/04/15 04:00 PM
NH
NH
When my cuda was an auto I had a reverse pattern manual valve body and it was a full street driven car that was also run on street nights at the track. I modified the gates on the factory Slap stick shifter to work in reverse ,worked great.
Re: Which manual valve body to look for? [Re: torredcuda] #1770209
03/04/15 04:03 PM
03/04/15 04:03 PM
BradH Offline
BradH  Offline
... a full street driven car that was also run on street nights at the track.
That's how I'd describe my Challenger, too; it's a street/strip car... when it's running.
Re: Which manual valve body to look for? [Re: DusterW2] #1770210
03/04/15 04:05 PM
03/04/15 04:05 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
www.atiracing.com
P/N 723210, $49.00
Is there any literature/books to buy that explain this process? I have stacks of valve bodies and a mill + tons of spare time.
Re: Which manual valve body to look for? [Re: CTD5.9] #1770211
03/04/15 04:16 PM
03/04/15 04:16 PM
NH
NH
Re: Which manual valve body to look for? [Re: torredcuda] #1770212
03/04/15 04:24 PM
03/04/15 04:24 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
thanks, ordered
Re: Which manual valve body to look for? [Re: CTD5.9] #1770213
03/04/15 05:08 PM
03/04/15 05:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Munroe's book won't show the transfer plate mods needed to build a RMVB. The pic below shows (in red) the channel partition areas that need to be removed. (1/4" cutter)
For those without a milling machine, a thick steel plate with a 1/4" hole drilled in it can be used. Place the hole over the area to be removed, clamp the steel plate to the transfer plate with two C-clamps and drill out the partitions using a 1/4" drill bit...mark the depth on the drill bit to prevent drilling too deep.
Re: Which manual valve body to look for? [Re: John_Kunkel] #1770214
03/04/15 05:20 PM
03/04/15 05:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On the main valve body, in addition to the kickdown valve mod, the 1-2 shift valve area needs mods and some components need to be tossed. '71-later shown but earlier is similar.
