Re: Which manual valve body to look for?
[Re: BradH]
#1770199
03/03/15 10:39 PM
03/03/15 10:39 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
How about making a full list for future reference?
1. Street only, forward pattern
2. Street only, reverse pattern
3. Street/Strip, forward pattern
4. Street/Strip, reverse pattern
5. Strip only, forward pattern, LBA (?)
6. Strip only, reverse pattern, LBA
Should there be 727 and 904 breakdown? Does HP change VB application?
[Re: RodStRace]
#1770200
03/03/15 11:40 PM
03/03/15 11:40 PM
Posts: 1,030 NH
torredcuda
NH
[Re: torredcuda]
#1770202
03/04/15 12:30 AM
03/04/15 12:30 AM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
You could make your own Rev manual using a good core VB and purchasing an ATI separator plate. Using a mill or drill press with an end mill, you can modify the channel walls and reassemble the kickdown valve and throttle pressure valve in the correct orientation. www.atiracing.comP/N 723210, $49.00 Otherwise, the Griner 22G05B is the superior RMVB available. Can also contact John Cope and coperacingtrans.com 727specialist is a dealer for Griner
[Re: RodStRace]
#1770207
03/04/15 03:35 PM
03/04/15 03:35 PM
BradH
IMO, options #1 & 2 make no sense; 99% of the people use a MVB in either street/strip cars or race cars.
Everybody else can leave it in "D".
[Re: BradH]
#1770208
03/04/15 04:00 PM
03/04/15 04:00 PM
Posts: 1,030 NH
torredcuda
NH
When my cuda was an auto I had a reverse pattern manual valve body and it was a full street driven car that was also run on street nights at the track. I modified the gates on the factory Slap stick shifter to work in reverse ,worked great.
[Re: torredcuda]
#1770209
03/04/15 04:03 PM
03/04/15 04:03 PM
BradH
... a full street driven car that was also run on street nights at the track.
That's how I'd describe my Challenger, too; it's a street/strip car... when it's running.
[Re: DusterW2]
#1770210
03/04/15 04:05 PM
03/04/15 04:05 PM
Posts: 760 Canada
CTD5.9
Canada
www.atiracing.com
P/N 723210, $49.00
Is there any literature/books to buy that explain this process? I have stacks of valve bodies and a mill + tons of spare time.
[Re: CTD5.9]
#1770211
03/04/15 04:16 PM
03/04/15 04:16 PM
Posts: 1,030 NH
torredcuda
NH
[Re: torredcuda]
#1770212
03/04/15 04:24 PM
03/04/15 04:24 PM
Posts: 760 Canada
CTD5.9
Canada
[Re: CTD5.9]
#1770213
03/04/15 05:08 PM
03/04/15 05:08 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Munroe's book won't show the transfer plate mods needed to build a RMVB. The pic below shows (in red) the channel partition areas that need to be removed. (1/4" cutter)
For those without a milling machine, a thick steel plate with a 1/4" hole drilled in it can be used. Place the hole over the area to be removed, clamp the steel plate to the transfer plate with two C-clamps and drill out the partitions using a 1/4" drill bit...mark the depth on the drill bit to prevent drilling too deep.
