Guys,
I'm converting my stock Mopar throttle/kickdown setup to a cable driven one. However, given that I need to make a few adjustments I need to get a few extra pieces. Pictures below show the setup I'm using. The 2 end adapters is what actually hooks up to the carb throttle lever and/or trans kick-down level. I can't for the life of me find the adjuster 'rod/screw' with a set screw - the piece in the picture below circled in RED - (proper name is???)...this is where the cable end goes into, then the set screw tightens it down, this 'screw' then goes into the adapter with the 1/4-28 stud in it.
Any ideas where the heck to find this? I see that Summit/Jegs show the end piece, many combos, but I can't find the other piece anywhere. I'm thinking of trying a bike/motorcycle shop next...
