Where to find this throttle cable adjuster combo? #177016
12/28/08 12:34 PM
12/28/08 12:34 PM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
Guys,
I'm converting my stock Mopar throttle/kickdown setup to a cable driven one. However, given that I need to make a few adjustments I need to get a few extra pieces. Pictures below show the setup I'm using. The 2 end adapters is what actually hooks up to the carb throttle lever and/or trans kick-down level. I can't for the life of me find the adjuster 'rod/screw' with a set screw - the piece in the picture below circled in RED - (proper name is???)...this is where the cable end goes into, then the set screw tightens it down, this 'screw' then goes into the adapter with the 1/4-28 stud in it.
Any ideas where the heck to find this? I see that Summit/Jegs show the end piece, many combos, but I can't find the other piece anywhere. I'm thinking of trying a bike/motorcycle shop next...
Re: Where to find this throttle cable adjuster combo? [Re: Diplomat360] #177017
12/28/08 10:36 PM
12/28/08 10:36 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Not sure what you need, could you use some allthread rod with some "JAM" nuts between the two pieces to get some extra length.
Re: Where to find this throttle cable adjuster combo? [Re: Diplomat360] #177018
12/28/08 10:53 PM
12/28/08 10:53 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Lokar sells this..
Looks similar to what you have...would give you the bit with the setscrew at least?
Re: Where to find this throttle cable adjuster combo? [Re: OzHemi] #177019
01/01/09 07:39 AM
01/01/09 07:39 AM
Windsor, ON, Canada
Windsor, ON, Canada
Yup, this is good...bummer about the price...man, $23 for that piece alone?
Well, I'll check a few more local places first.
Thanks again guys!
