Powertrax locker #176955
12/28/08 09:39 AM
12/28/08 09:39 AM
Colorado
hemiluver Offline OP
Colorado
Guys,
Have any of you tried a Powertrax 1240-Lock right locker? Are they srong enough for a 3700 lbs car with 500 rwhp and a stick? Also how do they work on the srteet? Thanks-Gary
Re: Powertrax locker [Re: hemiluver] #176956
12/28/08 11:03 AM
12/28/08 11:03 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I used one in a 8.25 for a while, and it locked like a spool when it was locked. It would ratchet OK around tight corners like stop signs, but it needed a little bit of gas to ratchet around longer corners, like at larger intersections. If you just coasted through those trailing throttle, it would pop really loudly as it was forced to ratchet. Just a little gas would cure that, but you have to be conscious of that fact when you drove. An automatic car may not have that issue, but you're driving a stick, too.
In the end, I decided it was too harsh for my 99% street car, but would be awesome in a real 50/50 or track-only car. Even better for an off-road truck with an auto trans.
Clair
Re: Powertrax locker [Re: hemiluver] #176957
12/28/08 02:46 PM
12/28/08 02:46 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
I had one in a 9-C1 police package caprice, It worked OK but scared the crap out of anybody else that borrowed it, they were sure something was broken the first time it wold "POP" on them going around a corner. I ended up taking it back out.
Re: Powertrax locker [Re: hemiluver] #176958
12/28/08 03:33 PM
12/28/08 03:33 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
I have used them in full sized chevy,fords 4x4, hard offroading and no problems. only thing i did not like is they didnt want to release going around a tight turn and the tire would drag, this is on short wheelbase trucks ( bronco/blazer )
Re: Powertrax locker [Re: hemiluver] #176959
12/28/08 10:04 PM
12/28/08 10:04 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I blew one up on my truck, on a decent built 360 with no nitrous. I was running a mustang at the time on the street. I would not put one in my current truck set up. It weight 4200 lbs and has over 400 at the wheels.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
