Overdrive Auto behind BB??
#17677
10/09/05 09:48 PM
10/09/05 09:48 PM
How hard would it be to put one of the newer overdrive automatics behind a 383 in a b-body? What would it cost and how much work would it take? Thanks
Re: Overdrive Auto behind BB??
#17682
10/10/05 01:53 AM
10/10/05 01:53 AM
Thank you! That gives me something to start with.
#17683
10/10/05 02:27 AM
10/10/05 02:27 AM
Posts: 2,273 Bern, Switzerland
6o4o
Bern, Switzerland
This crossmember hackjob is just a 100% no-no for me on this swap. I don't know how how to solder and I would never cut my car because of an OD, then I really like the GV OD better where mostly (there are also people that had to cut their floors!) an airhammer is all you need... considering this and the 80$/hour I would have to pay someone to do all the welding for me this swap becomes at least as expensive as an GV OD, doesn't it?
That's from the Hotrod magazine article "Before you start planning this summer’s family vacation in your overdrive Hemi Charger, remember that this is not a project for the faint of heart—or wallet. The retail price for an A518 is around $1600 (not including the torque converter), and the JVX adapter kit adds another $495. That’s more than two grand, and you haven’t even started grinding metal or fabricating linkage pieces, which can cost in the neighborhood of $800, according to Art Carr. But if you’re willing to spend the time and money, this is a great way to give an old Mopar new shifts."
[Re: 6o4o]
#17685
10/10/05 08:30 AM
10/10/05 08:30 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
6040, do some more investigating, IIRC, there's a few guys with '71-up B bodies that didn't have to cut and weld on the floorpan for a 518, they just had to remove a few ribs on the case of the OD and fabricate the bolt-in portion of the xmember....
[Re: 6o4o]
#17687
10/10/05 07:38 PM
10/10/05 07:38 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Who buys a new tranny? Grab a used one and rebuild it. It's not appreciably more than a 727. I can understand having difficulties finding one outside the US, but there should be no problems in the country.
#17688
10/10/05 08:11 PM
10/10/05 08:11 PM
Posts: 3,344 Central TX
roe
Central TX
Wasnt there supposed to be a direct bolt in job for the OD tranny from Jamie Passon(check spelling), or something like that? If so, is it available yet, has anyone used it? Results?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#17689
10/10/05 08:15 PM
10/10/05 08:15 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
thats a 4-speed 833 with different ratio's and its comparably priced to the gear vendors unit.
[Re: AlexP]
#17690
10/10/05 08:20 PM
10/10/05 08:20 PM
roe
Central TX
Does anybody remember the title of the post, I would like to do some reading on it. If you can, please post a link.
Thanks roe
[Re: feets]
#17691
10/10/05 08:33 PM
10/10/05 08:33 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
You'd think by now, someone can sell the tranny mount already modified: So folks who can't weld can just bolt her up. Ditto w/outlining exactly where on the tranny case you can grind/cut off to fit your car (I think only e-body and '71-'74 b-body you can do this w/o cutting your tunnel). 'specially if Keisler is probably going to charge big bux for a GM Trans conversion in your Mopar.
[Re: feets]
#17692
10/10/05 10:13 PM
10/10/05 10:13 PM
I agree with this. You can find 518's around here rebuilt for under $800, a low mile junkyard unit will be MUCH less. Welding isnt a huge expense either. Most muffler shops will weld a crossmember for you for $30 or so if you already have the measurements you want and the parts cut out. Anyone with a tape measure and an angle grinder could do this.
#17693
10/11/05 08:30 AM
10/11/05 08:30 AM
Posts: 1,913 Brunswick, Jawgia
Snailpower
Infinitely Fast Snail
Brunswick, Jawgia
If I can do it, most all of you can too! Take a look. It's not that hard... This pic is before the second bolt holes were drilled in the crossmember ears, or the mount was attached.
70 Coronet- turbocharged 360/518/3.73 SG
[Re: Snailpower]
#17694
10/11/05 08:35 AM
10/11/05 08:35 AM
Snailpower
Brunswick, Jawgia
Heres a pic of the crossmember modification. A little entailed, but stronger than the factory.
