Problem re-attaching steering coupler to shaft #176556
12/27/08 07:56 PM
12/27/08 07:56 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
I've been trying to re-install my steering coupler to the steering shaft, and am having trouble getting it to slide on. There's still about 1/2" to go before I can insert the rolled pin. The FSM doesn't say anything about needing a special tool to do this, but it does say to "align the master spline". I didn't notice any difference in any of the splines when I attached it. Is it even possible to get it onto the shaft if it's not aligned correctly? Any suggestions would be much appreciated - thanks!
Roger
Re: Problem re-attaching steering coupler to shaft [Re: Fab64] #176557
12/27/08 08:18 PM
12/27/08 08:18 PM
You would have to beat on it hard if the master splines were not aligned. Turn the input shaft to straighten the wheels, the master spline is in the top when centered. Put your glasses on if you are old like me. If the steering linkage is not connected, go lock to lock and find the middle. Once the splines are aligned, you can tap it down until the roll pin fits. You can tap firm, but not hard. You may have a bugered spline or dirt. Clean and inspect if necessary. Use a wide channel lock pliers to press the roll pin rather than tap it down.
Re: Problem re-attaching steering coupler to shaft #176558
12/27/08 08:35 PM
12/27/08 08:35 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Here is a bad pic of the master spline on the gear box, it is facing up. The matching spline inside the coupler is marked on the outside by that indent or divit, looks like I see yours to the left a bit.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Problem re-attaching steering coupler to shaft [Re: mopargem] #176559
12/27/08 09:13 PM
12/27/08 09:13 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Ok, thanks guys. I did locate the master spline. It's actually a "double-wide" spot on the shaft where it looks like a spline is missing. That, along with the key piece of information - the indent on the coupler - allowed me to line them up and the coupler slid right on. Moparts comes through again!!
Re: Problem re-attaching steering coupler to shaft [Re: Fab64] #176560
12/27/08 09:43 PM
12/27/08 09:43 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Plus its tough to do when you are by yourself.
Re: Problem re-attaching steering coupler to shaft [Re: CYACOP] #176561
12/28/08 11:22 AM
12/28/08 11:22 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Master spline in coupler.
Re: Problem re-attaching steering coupler to shaft [Re: Snoopy] #176562
12/28/08 11:22 AM
12/28/08 11:22 AM
Snoopy Offline
Snoopy  Offline
Another
