70 Dart- data tag
#1764045
02/26/15 11:41 PM
02/26/15 11:41 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
Yep, still winter but getting closer to spring We are bringing this Dart back to life. bought it 2 years ago Won't be factory when finished, but wonder what was when new. V21 V8X Y05 END M21 M43 N41 M42 N85 R11 VX1 C16 C55 G31 J45 FYI H6X9 TX9 107 143050 E55 D32 LM29 HOR 196081 someone put a 2 barrel on the 340 (non Number eng) added a 4 speed bench seat since it needs quarters and trunk, we are going to tub it for 10" x 15" rallye wheels narrowed rear and move the springs in. Have the fresh built 340 and 4 speed ready to go A new pistol grip and hurst shifter the front rotors will be changed to BBP
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
Re: 70 Dart- data tag
[Re: draginmopars]
#1764046
02/26/15 11:56 PM
02/26/15 11:56 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
E55 340 D32 727 torque flite automatic trans FY1 Yellow H6X9 Black bucket interior X9 black upper door frames 107 Jan 7th build date V1Xblack roof C16 console C55 bucket seats G31 something to do with glass that I don't remember J45 hood pins M21 chrome trim of some sort maybe drip rail?? M43 same but I don't remember N41 dual exhaust N42 bright exhaust tips N85 tach R11 am radio V2X Maybe a pin stripe black - not clear on the V2 code V8X bumble bee stripe black Y05 sale bank car (ordered for stock not pre-sold, generally) End well that's the end
Not too bad from memory
OK, I couldn't resist I grabbed my book,
G31 right outside manual mirror M21 is drip rail m43 bright grille trim V21 performance hood treatment
I was correct on the rest I think.
Careful, your character's showing!
[Re: mopar346]
#1764047
02/27/15 12:08 AM
02/27/15 12:08 AM
draginmopars
smyrna,tn
Thanks looks correct
when we pulled the carpet could see where the console brackets were
Howard
[Re: Rhinodart]
#1764050
02/27/15 02:56 AM
02/27/15 02:56 AM
draginmopars
smyrna,tn
Too bad you are going to cut it up, not many left and good color/options. I got 29x10.5x15 slicks in my Dart without tubbing, just moving the springs inboard and custom offset wheels. Only had to use the hammer in a couple spots on the inner wheelhouses after a few passes to see where the rubber was...
Gonna make it a clean cut 3 1/2" strip to widen the tub, all welds on the inside of the tub. like we did on the 71
If I had the original Eng, Trans, console, bucket seats. I would keep it Factory
also it needs both front floor pans, spare tire well, both trunk extensions and quarters, rear valance.
plus, we have a narrowed Rear and 10" x 15" rally wheels just laying here
When we went to look at a green 70 Dart We went there to buy the roof for the 72 Dart, but had to buy the yellow one in order to get the green 70 parts car.
When I saw the yellow one, i saw
Howard
[Re: draginmopars]
#1764051
02/27/15 03:21 AM
02/27/15 03:21 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
FWIW (round numbers) 1970 US specs.: 340 Swingers LM23H0 ~ 10,000 total w/V21 hood paint ~2,500 total (1 in 4) w/C55 buckets ~2,000 total (1 in 5) w/C16 console ~1,000 total (1 in 10) w/FY1 "TOP BANANA" ~1,000 total (1 in 10)
[Re: BigMoneyLewis]
#1764053
02/27/15 03:54 AM
02/27/15 03:54 AM
draginmopars
smyrna,tn
not directed at anyone Just asking since alot of other sheet metal is getting replaced Is tubbing it that bad?? The next owner, could always put the stock rear under it with 14" rallys and most people wouldn't notice the tubs like I said, so much original is missing> eng/ trans The green 70 Dart I could get the trans and linkage out of to put it back automatic Maybe watch for some seats and console. The 340 we built will still be wrong due to casting date
Howard
[Re: draginmopars]
#1764056
02/27/15 01:46 PM
02/27/15 01:46 PM
Posts: 3,065 N.W. Florida
Fat_Mike
N.W. Florida
Just asking
Some folks are purists, and prefer that every old Mopar stays original (no disrespect intended). I tend to think like you; with the drive train and important pieces of the interior missing, it's going to cost much more to make it APPEAR original than it would to make it the way YOU want it...and you'll never get that money back out of it. Press on...
[Re: draginmopars]
#1764059
02/27/15 06:23 PM
02/27/15 06:23 PM
6bblgt
Las Vegas, NV
50% of the "numbers matching" cars aren't! It's a hobby & a loosing proposition either way. you can spend time & money making it appear as a factory correct musclecar, & get a ~50% ROI you can spend time & money making it appear as a custom "hot rod", & get a ~25% ROI It's your money that you can spend/invest/dispose of as you desire ..... but there is value in the "original bones" of a 340 Swinger, that value is lost once it becomes a "custom". Quality body, paint, parts all cost time & money: STOCK or CUSTOM
[Re: pa340dart]
#1764061
02/27/15 11:02 PM
02/27/15 11:02 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree with Dan, there are fewer truly numbers matching 340 cars out there than most realize. While lacking the numbers drive train does decrease the value a bit, it doesn't automatically degrade it to race car status in terms of value or collectability. Also, if you want to make it faster than stock you can accomplish that just fine with stock wheel wells, no need to hack on the car.
Just one more opinion, but if that car were mine I'd buy and replace stock replacement parts that it's missing (seats, uncut rear end, etc.) and build either s stock replacement 340 drive train for it, or a little stroker version if you want some more go.
*BTW, my 71 340 Duster also lacks it's original engine and trans, I'm heading my own advice on my own car.
